Forum Index : Microcontroller and PC projects : List of Devices Running MMBASIC
| Andrew_G Guru Joined: 18/10/2016 Location: AustraliaPosts: 898 |
Hi, Sorry to ask an obvious question but where is the list of devices that run MMBASIC? (There was one, but I've lost track of it . . .). eg, MMDOS, MicroMite (MM), MM+, . . . F4, Pico . . . It would be nice if it could list items such as: - Common name - Processor(s) - Speed range - Memory - usable pins - particular features, strengths or weaknesses. . . . Could it be made as a sticky or prominent in Fruit if the Shed? Many thanks, Andrew |
Chopperp![]() Guru Joined: 03/01/2018 Location: AustraliaPosts: 1131 |
Hi Andrew Just had a quick look at the Armmmite H7 manual and on pages 4 & 5 & there is a bit of a summary of the Micromite family. It is a bit out of date though. EDIT The F4 manual is more up to date Page 11 Brian Edited 2021-12-19 10:29 by Chopperp ChopperP |
Hi Brian, Thanks for that. Yes that is the one I had lost track of. Its missing details on the CMM2s, Pico etc. and it will be hard to keep up-to-date tucked away in a manual for one sub-species. I guess that I'm suggesting that someone cleverer than me makes it a standalone document that can be referenced in future manuals and is easier to keep current. Thanks again, Andrew |
Cyber![]() Senior Member Joined: 13/01/2019 Location: UkrainePosts: 161 |
Here is the last one I compiled: https://www.thebackshed.com/forum/ViewTopic.php?TID=13224&P=1#161115 Still haven't added other items to it. |
