Local Time 19:10 16 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite: MCP4922 DAC on SPI
Calli
Posted: 02:57pm 22 Dec 2021
I used this DAC before and think it is a nice chip.
Here is some code which works for me and might get you started.
' MCP4922 Dual 12bit DAC
SetPin GP2,GP3,GP4,SPI
SetPin GP6, DOUT
Pin(GP6) = 1
SPI open 4000000,0,16
For a% = 0 To 4096-8 Step 64
' CS Down (LOW Active)
Pin(GP6)=0
'  DACn Write Buffer Gain_ Shutdown_
'           DWBGS
junk = SPI(&B0111000000000000 + a%) ' 1st DAC
Pin(GP6)=1
Pin(GP6)=0
junk = SPI(&B1111000000000000 + a%) ' 2nd DAC
' CS
Pin(GP6)=1
'Print a%
'Pause 300
Next a%
SPI CLose
Datasheet:
https://www.mouser.de/datasheet/2/268/21897a-70809.pdf
Be sure to get the active LOW-Pins LDAC_ and SHDN_ right, LDAC_ to LOW/GND will trigger the conversion every time the CS_ is rised, so we can save one Pin on the Picomite. Tie SHDN_to VDD to have the chip work.
Cheers,
Carsten
Tinine
Posted: 07:32pm 22 Dec 2021
Appreciated but can I suggest somewhere that it won't get lost?
Calli
Posted: 11:49am 29 Dec 2021
  Tinine said  Appreciated but can I suggest somewhere that it won't get lost?
http://www.fruitoftheshed.com/MMBasic.PicoMite-MCP4922-DAC-on-SPI.ashx
C!
twofingers
Posted: 12:20pm 29 Dec 2021
Thanks Carsten!
FYI something similar from Peter (matherp): Micromite MK2: MCP4822 DAC
Best regards
Michael
BTW: Micromite MK2:MCP342x i2c ADCs
The lone and ...
