Local Time 17:05 16 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Need Help for thermal printing in Picomite
Vampire05
Posted: 10:28am 19 Jan 2022
Hi Guys,
i try to print bit image data on a cheap thermal printer, but i do not understand the protocol.
On page 29 (Bit Image Command) in the manual:
https://cdn-shop.adafruit.com/datasheets/CSN-A2+User+Manual.pdf
i want to print a single dot / line and i have tried:
Print #1, Chr$(27)+Chr$(42)+Chr$(48)+Chr$(49)+Chr$(49)+Chr$(&B11111111)
I do not understand the nL and nH Parameter to print.
Does anyone have an example to print a line / dot in mmbasic?
Printing in Text mode works perfectly !
Best regards
Edited 2022-01-19 20:29 by Vampire05
flasherror
Posted: 12:59pm 19 Jan 2022
  Vampire05 said  i want to print a single dot / line and i have tried:
Shouldn't the Chr$(48) be Chr$(0) or Chr$(1) for single/double density? P29 says "Range for m =0,1,32,33". You are sending "ASCII 0" instead of 0.
Manual also says "If the value of m is out of the specified range, nL and nH the data following are processed as normal data."
What does the printer print when sent your data?
Edited 2022-01-19 23:04 by flasherror
Vampire05
Posted: 01:38pm 19 Jan 2022
 Thats it. Thank you very much flasherror!
Posted: 04:42am 21 Jan 2022
These are lovely little printers and work well.
I changed the internal font from the Chinese extended characters, to "Code Page 437" to give me more standard ASCII graphics characters for drawing boxes etc.
There was a little programming utility you could get for these printers that allowed you to change the internal font and the default baud-rate.
I can't remember where I got that from now, or where I put it, so if you have that utility, please link or upload it here.
