Local Time 16:08 16 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : datetime$ error on picomite
k2backhoe
Posted: 04:06am 26 Jan 2022
This works as per the User Manual
> ? datetime$(now)
25-01-2022 10:53:50
But if I try a number instead of now, I get
> ?datetime$(0)
Error : 0 is invalid (valid is -2147483648 to 2147483647)
when I should get (as I read the manual)
01-01-1970 00:00:00
All other numbers do the same.  Am I misreading the manual?  I tried to do a search on datetime$ but couldn't find a forum entry.
Thanks, k2
panky
Posted: 04:35am 26 Jan 2022
@k2backhoe
Peter may elaborate but I suspect that now is an internal function to return the current date and time in a format that epoch and datetime$ can use. Ie. it is not a variable available to users.
I think if you wish to set the date and time to specific values, you will have to use the date$ and time$ commands
eg.
date$ = "01-01-1970"
print date$(now)
gives
01-01-1970 0
I have no idea where the trailing 0 comes from - I suspect it is a bug?
Doug.
Edit: On reflection, the trailing 0 I believe is the other part of the 'now' internal component. I used the example of just date$ above so the time component of 'now' was not needed by date$ hence the '0'.
The short answer to this is 'don't use now in date$ or time$, just datetime$ or epoch'. D.
Edited 2022-01-26 14:40 by panky
Posted: 05:21am 26 Jan 2022
k2backhoe has identified an omission in datetime$. The error message suggests (as per the manual) that it is trying to process an epoch number but failing.
some results are:-
> date$="26-01-2022"
> time$="16:12"
> ? date$, time$
26-01-2022      16:12:29
> ? DATETIME$(now)
26-01-2022 16:13:31
> ? DATETIME$(epoch(now))
Error : 1643213634 is invalid (valid is -2147483648 to 2147483647)
> ? epoch(now)
1643213683
> ? epoch(DATETIME$(now))
1643213743
> ? epoch("26-01-2022 16:13:31")
1643213611
Posted: 07:58am 26 Jan 2022
I found/fixed the bug when testing the windows version will retrofit to the PicoMite in next release
k2backhoe
Posted: 03:14pm 26 Jan 2022
matherp and phill99, thanks so much for the prompt and comprehensive replies.  I can work around this without a problem until the next release.
PS. I love picomite basic, it is an excellent language that does exactly what I need to do.  Thanks for it.
VK2XG
Posted: 12:29am 30 Jan 2022
Likewise Thanks.
And sorry for adding a new post on this subject.
Looking foward to the next Picomite version.
