Local Time 13:11 16 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Help
RicM
Posted: 03:31am 13 Mar 2022
Dear Members,
I am testing a CMM2 Generation 1 before I purchase it.
The MM.INFO$(CPUSPEED) command not working and all other MM commands.
Firmware is 5.6.0
RicM
Posted: 03:36am 13 Mar 2022
What kind of not working? What is the exact command you are using and the output or error message?
Posted: 03:49am 13 Mar 2022
MM.INFO$(CPUSPEED) is a preset variable not a command.
To see it's value type:-
PRINT MM.INFO$(CPUSPEED)
or
PRINT MM.INFO(CPUSPEED)
Edited 2022-03-13 13:51 by phil99
Posted: 03:41am 14 Mar 2022
@phil99 is correct, you need to PRINT the value.
Ric, it sounds as if you need a tutorial on the BASIC language,
I recommend: https://geoffg.net/Downloads/Maximite/Programming_with_the_Colour_Maximite_2.pdf
Start at page one and work your way through at least the first 24 pages.
As @lizby said, if you are going to post a question about something "not working" you need to post the exact command or code fragment and the exact error message as seen on the screen.  Then people can help you.
Finally, the CMM2 either works or it does not work.  It does not "half work".  So if your CMM2 has booted up and you can enter a simple command you can be assured that you have a working CMM2.
Edited 2022-03-14 13:58 by Geoffg
