Local Time 12:16 16 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite - using ILI9341 panel as a console
marvbloke
Posted: 08:58pm 17 Mar 2022
Hi all,
Firstly a big thanks to everyone involved in bringing MMBasic to the Pico. I'm loving this project!
And now for my first problem. I've got PicoMite/MMBasic running well on a breadboard using a Waveshare 2.4 inch LCD (ILI9341 SPI display). It looks great, and runs the circles demo really well. However, I'm hoping to use it as a console (using OPTION LCDPANEL CONSOLE), which works fine until you get to the bottom of the screen. Instead of scrolling, most of the screen turns white apart from the bottom row of text. Here's a video which shows the problem better than I'm describing it.
The manual does mention issues with scrolling, but wondered if there was a solution to the issue?
Edited 2022-03-18 06:59 by marvbloke
Posted: 10:48pm 17 Mar 2022
You haven't got MISO connected
marvbloke
Posted: 09:34am 18 Mar 2022
Ah - that's it. This particular panel doesn't have a MISO connection, so I've ordered a couple that do. Thanks!
al18
Posted: 08:32pm 18 Mar 2022
I believe the PicoMite firmware supports both the Waveshare PicoTouch 3.5 inch LCD and the Waveshare Pico Evaluation board with the same 3.5 inch LCD and a lot more sensors
Posted: 10:32pm 18 Mar 2022
  Quote  I believe the PicoMite firmware supports both the Waveshare PicoTouch 3.5 inch LCD and the Waveshare Pico Evaluation board with the same 3.5 inch LCD and a lot more sensors
and neither of those have MISO available so cannot be used as console devices
hitsware2
Posted: 11:20pm 18 Mar 2022
This one works ..
my site
al18
Posted: 01:50am 19 Mar 2022
Please report back to confirm if the 2.8 inch display works. Both of the 3.5 inch displays I mentioned have pin GP12 labeled as SPI MISO pin.
Posted: 07:11am 19 Mar 2022
GP12 is the SPI MISO pin for the Pico, the issue I think Peter is referring to is that the display does not have it's MISO (also called SDO) output available to connect to the Pico on those units.
Posted: 07:51am 19 Mar 2022
There are only three SPI displays that can be used as (very slow scroll) console devices.
ILI9341 (but only if MISO is available), ILI9488/86 (connect MISO with a 680ohm resistor as the controller doesn't tri-state properly) and the 2.8" Waveshare ST7789
marvbloke
Posted: 08:30am 19 Mar 2022
Thanks everyone. The project I'm working on needs a 2.4 inch screen - no bigger. So the ones I've ordered (which are 2.4 inch ILI9341 with a MISO connection) should do the trick. I'll report back after they arrive next week.
hitsware2
Posted: 04:13pm 19 Mar 2022
Definitely works
  al18 said  Please report back to confirm if the 2.8 inch display works. Both of the 3.5 inch displays I mentioned have pin GP12 labeled as SPI MISO pin.
( Do not know about specific needs )
my site
