Local Time 13:11 16 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : picomite IR implementation issues
jovian
Posted: 09:17am 20 Mar 2022
HI
I want to to quickly poll 18 IR LEDs from one picomite, (via Darlington transistor arrays)
I have successfully tested a scratch piece of software that polls around the pins, and it runs no problem, with a 20 ms gap between each IR send command.
However, because the infrared commands take around 150 ms each to send, my concern is whether the firmware is smart enough to handle multiple channels of infrared sounds simultaneously, or whether the initiation of a new IR send command simply terminates any previous one.
Can anyone answer this question?
Joe
Edited 2022-03-20 19:19 by jovian
Posted: 09:23am 20 Mar 2022
The IR SEND command is blocking so only one can happen at a time
