Forum Index : Microcontroller and PC projects : NUCLEO-H743ZI2
| KeepIS Guru Joined: 13/10/2014 Location: AustraliaPosts: 2264 |
FYI - NUCLEO-H743ZI2 boards are back in stock at Digi-Key AU/US and still at same low price. NANO:Inverter V 8.4ks -Â Linux AvrDude GUI script V4.1 |
| al18 Senior Member Joined: 06/07/2019 Location: United StatesPosts: 251 |
Digikey US shows 1 in stock |
The site will only allow you to add one to the basket, however there may be more available, the ordering / shipping hoops and pay-pal procedure has changed, other stupid questions added. If someone orders one, we may find out? Otherwise there where only 3 available and I find that hard to believe as they "supposedly" just received new stock? As per previous posts by others on nil supplies of these, I could not get them anywhere until today. NANO:Inverter V 8.4ks -Â Linux AvrDude GUI script V4.1 |
I’m guessing a quantity of 3 were a customer return. |
Quite possibly BTW Real time? Edited 2022-04-06 14:59 by KeepIS NANO:Inverter V 8.4ks -Â Linux AvrDude GUI script V4.1 |
143 stock at Digikey looks good. Can this board be used to create a CMM2, like the Waveshare H743 board? |
| Mixtel90 Guru Joined: 05/10/2019 Location: United KingdomPosts: 9134 |
I think someone's brought this up before. IIRC it won't run the CMM2 firmware as it stands, although I may be wrong. Have a look for the ArmMite H7. Edited 2022-04-07 06:07 by Mixtel90 Mick Zilog Inside! nascom.info for Nascom & Gemini |
Mick, You were right - the ArmMite H7 runs on the Nucleo H743 board. |
Peter did a backpack for a Nucleo 144 some time ago. Any use? http://www.thebackshed.com/forum/ViewTopic.php?TID=10700#123737 Mick Zilog Inside! nascom.info for Nascom & Gemini |
