Forum Index : Microcontroller and PC projects : File Manager for picoMite
| Amnesie Guru Joined: 30/06/2020 Location: GermanyPosts: 763 |
Hello again, is there a File Manger for the picoMite available? I remember the "File Manager 2" for the CMM2, but this won't run on the pico... I tried to convert it to the pico, but with no success, since it is too different and I am not an expert. All I got converted was the line command and deleted some obsolete colour modes but after that I got in trouble with "Drive" command ... and the list goes on and on. But maybe I am missing something and there is a different file manager I might not know of... Greetings Daniel |
| Mixtel90 Guru Joined: 05/10/2019 Location: United KingdomPosts: 9134 |
Nope, it doesn't have one. It would probably be overkill. Why would you need one? Mick Zilog Inside! nascom.info for Nascom & Gemini |
I am using the picoMite VGA as a stand-alone computer and it would be handy, but no problem, when time has come I try to make my own. Til then I still have much to learn :) Greetings Daniel Edited 2022-04-07 02:39 by Amnesie |
It's a bit restricted as to what you can do when you look at the hardware. FILES is reasonably powerful and easy enough to use. Mick Zilog Inside! nascom.info for Nascom & Gemini |
