Local Time 09:39 16 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PM VGA RTC
Rickard5
Posted: 04:04am 26 Apr 2022
Can someone tell me how do you test the RTC on the PM VGA ? I found an RTC Module in my Arduino parts box not sure of it's status
Thanks in advance
al18
Posted: 04:32am 26 Apr 2022
Install the battery
Use the date$ and time$ to set the date and time
Enter Option RTC Auto Enable
Kill the power on your system
? Date$ Time$ to confirm the date and time was retained
Warning: If you installed a Lithium CR2032 battery, you’ll need to use a soldering iron to remove the glass diode from your RTC module. This will prevent the module from trying to charge the battery - which would overheat the battery.
Rickard5
Posted: 05:39am 26 Apr 2022
Thanks Al I got her on now charging the Battery that was preinstalled gone give it a try in a bit
al18
Posted: 09:57am 26 Apr 2022
Ok, please ignore my statement about removing the glass diode - it doesn’t apply in your case.
