Local Time 08:33 16 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : OPTION ERROR [ABORT|CONTINUE]  - Not in manuals
disco4now
Posted: 02:05am 02 May 2022
These have been purposely removed from the manuals and are depreciated.
ON ERROR [ABORT|IGNORE|SKIP|CLEAR] �is more flexible and should be used instead.
░░         WORK IN PROGRESS
░░                Please don't reply to thread       ░░░░
Hi Jim,
I think there is an issue with MMCC FileManager when downloading from Picomite/ArmiteF4/F7 to the PC. I discovered when trying to copy this screenshot back to the PC.(Windows 11)
screenshot0.zip
MMCC V537 2025/12/14  Download to PC OK
MMCC V540 2026/01/26  Download Fails
MMCC V541 2026/07/27  Download Fails
MMCC V537 2025/12/14  Upload OK
Processing file: screenshot0.BMP
Completed OK
Finished
MMCC V540 2026/01/26     Upload Fails
**ArmMiteF4**
Reverting to XMODEM
Short Block in #10
Long Block in #10
Short Block in #10
Long Block in #10
Long Block in #10
Long Block in #10
Long Block in #10
Long Block in #10
Long Block in #10
Long Block in #10
Long Block in #10
File transfer failed
Finished
¼`ⁿ
** Picomite ***
Reverting to XMODEM
Reverting to XMODEM
Short Block in #1
Short Block in #1
Short Block in #1
Short Block in #1
Short Block in #1
Short Block in #1
Finished
Hi Peter,
I noticed LIBRARY SAVE is not omitting comment lines when saving to the library.
The updated line below fixes  it so its skip byte aware and comment only lines are omitted.
There are two cases where the line length is changed during LIBRARY SAVE.
1. Multiple spaces are reduced to a single space.
2. Comments at end of lines are omitted.
Will you need to adjust skip byte to obtain the performance increase for code in the library. I have not checked the library as yet but I assume it will still work and fall back to normal when skip byte does not find the next line.
MM_Misc.c
void MIPS16 cmd_library(void)
   if (checkstring(cmdline, (unsigned char *)"SAVE"))
           if (*p == '\'' && !InQuote)
           { // found a modern remark char
               skipline(p);
               // PIntHC(*(m-3)); PIntHC(*(m-2)); PIntHC(*(m-1)); PIntHC(*(m));
               // MMPrintString("\r\n");
               // if(*(m-3) == 0x01) {        //Original condition from Micromites
               /* Check to see if comment is the first thing on the line or its only preceded by spaces.
               Any spaces before a comment are reduced to a single space so we treat a comment with 1 space before it
               as a comment line to be omitted.
              // This is test previous to skip byte being introduced.
               //if ((*(m - 1) == 0x01) || ((*(m - 2) == 0x01) && (*(m - 1) == 0x20)))
              // Updated to account for skip byte included from 6.03.00
               if ((*(m - 2) == 0x01) || ((*(m - 3) == 0x01) && (*(m - 1) == 0x20)))
                   m = TempPtr; // if the comment was the only thing on the line don't copy the line at all
                   continue;
               else
                   p--;
Hi Peter,
The files changed to implement commandline wrapping against RC4 are on GitHub
Updated files for CommandLine wrapping GitHub
Also some notes to go with the implementation.
PicoMite: Console Commandline wrapping
History
MMBasic allows a program line to be 255 characters. The Micromites allow a long commandline to be entered via the console by wrapping the command to the next line on the terminal. Limited correction/editing of the command is allowed by using the BackSpace key to go back and retype the last part of the command on the most recent line.
The Picomites were enhanced by adding a command history buffer and more editing capabilities. e.g. left/right arrow keys,Home,End,INS,Del and the ability to recall previous commands via the Up and Down arrow keys. The support for wrapping the command  to a second line was lost so commands entered via the console are limited to the console width.
This Update
This update restores the ability to wrap commands on the console to the full 255 characters. The command line wrapping has been designed to expect the VT100 terminal to have its terminal width set to Option.Width+1 to match the width expected by the EDIT command and now also the Console. Wrapping the command over multiple lines is also supported when the console is via on LCD Panel (i.e. OPTION LCDPANEL CONSOLE) or the screen on a PicomiteVGA.
TeraTerm,Putty and MMCC(MMEdit) can have the number columns and rows set by sending an escape sequence  with the number of rows and columns. (lets call it setterminal). MMBasic will attempt set the required number of columns and rows under the following rules.
* No setterminal is sent at the initial command prompt or when a program is started. i.e. it won't ever change your terminal size unless you trigger one the the following conditions.
* OPTION DISPLAY (with no parameters)
will attempt to set the terminal based the current values of Option.Height and Option.Width+1. Use this to initially set your terminal to match the default values.
(GFXTerm will need to have the terminal size manually set).
If OPTION LCDPANEL CONSOLE is in use Option.Width and Option.Height are determined by the font size used and can be less than the default sizes. The implementation will NEVER set the VT100 rows to less than 24(40 for PicoVGA) and columns to less than 81 based on the default terminal size.
* OPTION DISPLAY rows,columns
Sets Option.Height, Option.Width to the specified values and attempts to set the VT100 terminal to match.
* EDIT command will attempt to set the terminal based on Option.Height and Option.Width, but will NEVER set rows to less than 24(40) and columns to less than 81 based on the default terminal size. This means the VT100 is minimum 24*81 even if we have an LCD PANEL CONSOLE which is smaller.The EDIT command is happy with a terminal larger than it needs so the fullscreen editor on the VT100 and the LCD PANEL Console remain in sync if using both. If an LCD PANEL CONSOLE is greater than 24*81 then the VT100 will be set to match it.
* OPTION LCDPANEL CONSOLE font
This will also set the VT100 terminal based on the new calculated Option.Height and Option.Width to match the LCD PANEL console and font, but will NEVER set rows to less than 24 and columns to less than 81 based on the default terminal size.
* OPTION LCDPANEL NOCONSOLE
Will restore the VT100 to the default 24*81 size based on the now default Option.Height and Option.width after the LCDPANEL CONSOLE is disabled.
* OPTION LCDPANEL DISABLE (while Option.Console is set)
Will restore the VT100 to the default 24*81 size based on the now default Option.Height and Option.width after the LCDPANEL is disabled.
NOSCROLL and MM.PROMPT
When NOSCROLL is in used and a command is being enter that will cause a rewrite, the command is proactively written at the top of the console.
If a recalled command  (Up/Down arrow) will cause a rewrite it is proactively written at the top of the console including the > prompt so command is aligned as normal.
If MM.PROMPT is being used the alignment will match the custom prompt size.
EDIT Command fixes
These two small issues with the EDIT command are corrected.
(Note: the Micromites also have these issues)
The last character in a line is not shown in the editor if the line is exactly the length of the Option.Width
In Mark mode (select) a line of length exactly Option.Width gives message LINE TOO LONG if trying to select using F4 then END key.
Same message is given if try to select within a block with either the UP or DOWN arrow key.
Testing
Tested on Picomite and PicomiteVGA.
Not tested on USB versions or WebMite, but hopefully would work.
A quick test is to enter the line.
PRINT "the quick brown fox jumps over the lazy dog and now is the time for all good men to come to the aid of the party"
Try the Left/Right arrow keys, Home and End, backspace etc to check editing over multiple lines functions correctly.
VT100 terminals
Line wrapping tested on the following terminals.
They must allow terminal resizing of have the correct size set manually.
TeraTerm - OK
Putty    - OK
GFXTerm  - OK  (manual set terminal)
MMCC     - Will allow wrapping but a couple of issues if editing across multiple                 lines.
I have not tested any Linux terminals.
FotS: Fruit of the Shed Wiki - News
The Fruit of the Shed is now available on its new/original address https://fruitoftheshed.com
Getting Access
Anyone can read and search all the articles/pages.
Any shedders who would like to contribute can get write access via sending me a PM on here. If you have a full name and an email in your TBS profile then just say you want access and I will use those details, otherwise nominate the name and email to use in the PM. Your username will be your TBS username and the system will send you an email with the password once I create your account.
The Namespaces/Categories
All the original content should have been migrated, there has been some slight rearrangements of the original namespaces.
MMBasic
The MMBasic namespace remains for code snippets and general coding.
MMBasic Original
The original mainly Maximite library is now split off to MMBasic Original.
MMBasic Hardware
This namespace MMBasic Hardware Backpacks Firmware Manuals Games etc. is created to reference information for each port of MMBasic. Manuals,Firmware,Hardware, Backpacks,Adaptors, Games. etc
Wiki 101
Read this for tips on creating content.
Other Namespaces remain as in the original FotS.
Some Recent/Future Articles
Three Output States from One Pin (references Peter's post around using 1 pin to control both Touch CS and SD Card CS.
The recent post on a method of interfacing a rotary encoder could be made into an article with some more general info on rotary encoders.
Bounce Proof Rotary encoder
Hosting and Backup and Disaster Recovery stategy
The Fruit of the Shed has been migrated to DokuWiki on a hosted service on VentraIP.
Backup Levels:
Application:
Dokuwiki keeps a record of recent changes and pages can be recovered or reverted to previous revisions by any user with edit permissions.
VentraIP Acronis backup maintains :
a)2 hourly backups for the current day
b)daily backups for last week
c)weekly backups for last month
Nightly backup to My Dropbox maintains 3 full backups:
a)last day
b)last week
c)last month
This is synced to my PC and synology NAS. The backup directory in dropbox does not seem to be able to be shared with others,however a copy in another directory seems to be shareable. I have a scheduled task to copy the files each day.  Sharing this directory will allow the backup to be available to others.The three backup files are currently around 220MBtyes in total.
If anyone has Dropbox and wants to become a custodian of a last line of defense copy of the system I will share the folder with the three backups from my Dropbox.
DokuWiki is fully file system based and runs under PHP. All the content lives in two directories  data/pages, and data/media. If you have these two directories and the administration manual (which I am yet to write) you could rebuild the system from scratch. You would need to add the users and security manually.
DokuWiki seems to be widely used and still current with good documentation so hopefully it a good choice.
fruitoftheshed.com is registered to Nov 2030.
Hosting on VentraIP is valid until Nov 2027.
So hopefully FruitofTheShed will be around for some time to come.
Gerry
FotS Future - Update
  thwill said
Gerry, Lance, do we have a plan going forward? Is either of you willing to be primary custodian of this Fruit of the Shed reborn? If you use a GitHub wiki I can provide some initial technical support, but I am making it up as I go along with the help of Google.
Tom,
I have the zipped contents of the FotS. Its just under 40Meg and contains three directories. One for the pages, one for attachments and one for uploads. Those missing images appear to be links to images uploaded on TBS. Its too big to attach here, I have given a dropbox link to it below.
I have (before Xmas) gone most of the way to writing a script (Purebasic program) to translate all the tags and links to the format understood by DokuWiki. It should not take much to modify it for GitHub  wiki tags.
In December I invested in a hosting service for 12 months so I could see how DokuWiki would work with the contents of FotS. My hesitation was around it being supported by one person not getting any younger.  DokuWiki appears to be quite a commonly used wiki and available on most hosted services.
My initial thoughts were to get the contents into Dokuwiki and see how it looked.
The static copy of FOS will give a bit of breathing space.
I have had a play with github wiki. The links below shows the Bacpkack Curver tracer article on GitHub wiki and on DokuWiki.
As you can see the github wiki is capable of displaying the articles once converted. This article uses images from both an external site (TBS) and locally on GitGub wiki which can be displayed in line or as links.
In summary github wiki could be used to hold the FotS and it would be free. My concerns are:
FotS has 244 articles so 224 pages. The searching appears to only find words in the page title.
There does not seem to be a way to implement the equivalent of namespaces i.e. categorisation, so you would always be looking at a long list of pages.
For the repository to be cloned and work you need to use relative links.
To add assets e.g. images to the wiki you need to add via the interface (drag drop or select) They get added and referenced as below.
[Download PCB foil (solder side view)](https://github.com/disco4now/PicoMite/assets/49109003/bcc43a53-7b5f-45b7-b198-7ff24a173795)
You can edit to make them relative and they work as both a link and inline.
As a link:
[Download PCB foil (solder side view)](../assets/49109003/bcc43a53-7b5f-45b7-b198-7ff24a173795)
Inline:
![Download PCB foil (component side view)](../assets/49109003/df8abdd0-28ca-4d5b-ba01-e8229eaf1d67)
You can do a bulk upload to a directory in the repository and reference the files as  below.
[Download PCB foil (solder side view)](https://github.com/disco4now/PicoMite/blob/main/assets/trackerfoilss.png)
[Download PCB foil (component side view)](../blob/main/assets/trackerfoilcs.png)
A relative link to an asset add this way does NOT seem to work for inline, i.e.
![Download PCB foil (component side view)](../blob/main/assets/trackerfoilcs.png)
I do not see a way to bulk upload pages, so probably a cut and paste of prepared file would be required for each page.
There is no granularity in permissions. The options as I understand are collaborators have full access, and then a choice of all others all being given either full access or read only.
Curver tracer on GitHub wiki
This is the article shown on the DokuWiki I am playing with.
Curver tracer on Dokuwiki
My preferred option is to move the FotS to DokuWiki. I have it hosted on VentraIP and  would keep it going for as long as I am around.
It gives good searching, full granularity for permissions and seems to be a well used/supported wiki. I can also bulk load the pages and supporting assets.I have broken the back of this and have just been pondering the rearrangement of the namespaces.
I would see everyone having read access without a login and any TBS members in good standing. (i.e. a few posts and not kicked out) be given access on request to edit/ add pages. Multiple users can be made superuser to do admin if required.
I have not raised with Glenn but as its PHP and runs on Linux and is a common application once is a proven thing maybe one day it could become
https://www.thebackshed.com/wiki
I am proposing to slighly rearrange the existing namespaces to this:
The original MMBasic Library articles (78) (the zip file lizby is currently playing with) are moved to there own namespace. (they are early Maximite files mostly)
CMM2 merged with MMBasic Hardware.
Home Page
MMBasic               105 (was 183)
MMBasic Hardware       11 (was 4)
MMBasic Original       78 (was 0)
Circuit Ideas           9
Great Cow Basic         3
PIC ASM                 7
Platform Agnostic      11
CMM2                    0  (was 7)
This link is to the 38MB file containing the FotS content.
Contains:
Attachments 67 in 46 folders    17MB
Pages 224 in 7 folders          1.8MB
Uploads  98 files in 5 folders  22MB
fruitofthe shed content
So for now I am working toward getting the data loaded into DokuWiki.
Gerry
Hi Tom,
Some updated test files.
tst_math        Should now exercise all the MATH commands and Functions.
               It only checks that the complex number stuff doesn't error
               but most others do some type of test.
tst_memory      Should test all the memory commands
tst_longstring  Should include all longstring commands and functions
tst_error_handling  based on yours and includes tests for the various faults you have reported. Also uses mm.info(LINE) to calculate expected error line.
tst_pins    This exercises the various SPI,COM,PWM,I2C,ADC functions to see the pins           are reserved/released.
fortom.zip
Hi Peter,
Beta 2 Update F4
Using \\000 and \&00 (OPTION ESCAPE) give error message as per picomites
SPIClose() added before AppendLibrary incase left open by flash write fail
multiline comments support as per picomites  /*   */
fix for potential FILES error from peter.
BACKLIGHT value[,DEFAULT|REVERSE]
Gerry
Latest F4
CNTRL+SHIFT+x will close both the main MMbasic window and the command line console window. Handy if you want to reload from MMEdit which required MMB4W to be closed down.
-add as per picomite
READ SAVE
READ RESTORE
-serial ports
Support for serial comms (any or all of com1 - com63)
Parameters available for serial comms - syntax same as all other MMbasic
Baudrate as specified, default if not 9600
Receive Buffer size as specified, default if not 256
Receive Interrupt can be specified - default no interrupt
Receive Interrupt count can be specified - default 1
Parity - default NONE
Available: EVEN, ODD, MARK, SPACE
Data Bits - default 8
Available 7BIT
Stop bits - default 1
Stop Bits 1.5 supported. (S1P5)
Available S2, S1P5 (1.5bits)
INV not implemented -remove from OPEN command and Appendix A.
RS485 not implemented -remove references to DEN and DEP in OPEN command and Appendix
It is possible to send a break.
PRINT #1 ,BREAK
its a true BREAK set at 20 bit periods
Maybe a separate entry in PRINT command or in APPENDIX A
MODE command can take -ve mode value
Mode command - use a negative value for the mode and you will get full screen with no border e.g.
MODE -16 will fill a 1080p monitor perfectly as full screen with no border at the top.
You cannot set a full screen mode as the default.i.e OPTION MODE -16 would not be allowed.
FUNCTIONS
-missing function
COMPORT(portno) return 0 is port does not exist, 1 if exists.
FULL Screen Editor.
- new functionality
Home - Double press of Home in editor to move to start of the file
End -  Double press of End in editor to move to end of the file
Gerry
Edited 2026-07-29 22:26 by disco4now
F4 H7FotSF4xGT
