Local Time 07:38 16 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Picomite and Neopixel RGBW.
aargee
Posted: 11:20am 19 May 2022
Hello Geoff, Peter and all,
I would like to use the Picomite to drive one of theses:
4W RGBW Neopixel
I can run the RGB (albeit with the wrong colour allocation) using the BITBANG WS2812 command, but this outputs a 24Bit stream and hence just runs the RGB and not the White element, which requires a 32 bit stream.
Is this possible or will it be easier to jump back to an Arduino platform?
- Rob.
Posted: 12:10pm 19 May 2022
What happens if you just pretend there is a 2nd LED and put the white level in the 2nd array element? Assuming this works then with a bit of simple basic you can then drive strings by just setting bytes in the array appropriately
dim a%(n)=r1g1b1, w1r2g2, b2w2r3, g3b3w3 ........
Please report back if this works
Edited 2022-05-19 22:10 by matherp
aargee
Posted: 10:09pm 19 May 2022
Excellent Peter, that worked a treat.
In my case the RGB sequencing is around about, so it's the second byte in the second group that triggers the white.
e.g. the 24bit group triggers this way -
&HGGRRBB
So to turn on all LEDs including white at minimum brightness,
&HGGRRBB &HGGRRBB
&H010101 &H000100
and yes, if you make the other bytes 01 in the second group (&H010101) it will cause the green and red to light in the second LED array.
Something to work with. :-)
Posted: 07:12am 20 May 2022
  Quote  so it's the second byte in the second group that triggers the white.
That doesn't make any sense. Did you try the three timing variants to see which works best?
O = original WS2812
B = WS2812B
S = SK6812
aargee
Posted: 08:11am 21 May 2022
Peter,
I can confirm that all the variants (O, B or S) produce the same result as above, none of them change the colour sequence.
I'm using Picomite Ver 5.07.04
- Rob.
