Local Time 07:39 16 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : A GOOFY Terra Term Question
Rickard5
Posted: 01:11pm 21 May 2022
Hello, I got a weird thing going on, I Finley started messing with my Waveshare 3.5inch Touch Display so I'm having to connect Via Terra Term, and when I go in to edit, for some reason the function keys don't work. so I can't save or run anything
I'm hoping it's some terra term setting. Anyone got any ideas PLEASE
Thanks in advance
Posted: 05:10am 22 May 2022
Hi Rickard5,
Is the terminal set for VT100?
Rickard5
Posted: 06:42am 22 May 2022
YES in setup it is set to VT 100 and UTF-8
Rick
Rickard5
Posted: 06:54am 22 May 2022
Thanks Bigmik but I just figured it out, My Laptop PC is an HP and the Function Keys are also the shortcut Keys so if you want to use the function Keys you have to enable Function lock :(
Rick
q
