Local Time 03:15 16 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : T-PicoC3 display works great, pros and cons
k2backhoe
Posted: 01:06am 23 May 2022
The T-PicoC3 from Tindie has a lot going for it.  <$9 (plus $9 shipping for one or several boards) gives you a RP2040 machine that works with MMBasic (a must for my use). Plus it comes with a wired 135X240 color display fully drivable by MMBasic. Also two pushbuttons (gp6, gp7).  Plus there is a ESP32 supposedly supporting Bluetooth and Wi-Fi that I haven't begun to play with yet, all on one board.  Picture and sample code below.
One thing I haven't figured out yet, each time I reconnect it to Tera Term, I have to reload the .uf2 file in order for the serial channel to show up.  A real annoyance, but at least the flash programs are still there.
Warning:  I am presenting code with pin numbers that work.  It may be that different pin numbers should be used, but these make the image below very reliably.
I would welcome anyone else's comments, questions or corrections.
PS: The screen looks much better than my cruddy phone picture of it.
' T-PicoC3 test program
' OPTION SYSTEM SPI gp2, gp3, gp0
' OPTION LCDPANEL ST7789, LANDSCAPE, gp1, gp6, gp5, gp4
CLS RGB(100,150,60)
Text 0,12, "Text shows up HERE"
Circle 100,100, 30,10,1,RGB(green), RGB(blue)
Circle 120,80,30,10,1,RGB(red),RGB(200,0,200)
Circle 140,60,30,10,1,RGB(200,200,0),RGB(50,50,50)
Posted: 06:45am 23 May 2022
Have you got a circuit diagram for it?
The problem with this sort of thing is in knowing what things are connected to. Using pins that are normally used for something else on a PicoMite system can easily mess things up, as others have discovered.  :(
Another niggle that I have with this sort of thing is problems you can get if you want to actually use it in something rather than experiment on it. I'll take this board as an example, but that's only because it's convenient to do so. :) Almost all other modules have problems too. You have two mounting holes, both at the same end. If you want to use the ESP then you can't put anything metallic in the lower hole as it's too close to the antenna. The RH end is unsupported - where you need support because of the USB connector. You can't plug anything into the remote antenna socket without increasing the distance between the front of the screen and the rear of a front panel as the plug projects forwards. I'm not sure what the switch does, but it would need some sort of slider system to operate it from outside a box. Likewise the two buttons - they aren't the sort that can take button caps. These are minor things, but they make things awkward. It wouldn't surprise me if this board wasn't intended to be used in portrait mode with the buttons at the bottom and the switch accessible from the side for some sort of hand-held device.
Posted: 08:37am 23 May 2022
Schematic on here  I think.
Aha, this
Edited 2022-05-23 18:38 by JohnS
Posted: 09:47am 23 May 2022
An interesting little board, if a little restricted for external I/O.
Flip the USB connector over to connect to the ESP or the RP2040. Green & blue LEDs indicate which. Neat. :)
Battery charging from USB built in.
ADC0 (GP26) is tied to the battery voltage, but ADC3 (GP29) is wired out.
GP0 to GP5 are used by the display.
GP8 to GP11 are connected to the ESP.
You seem to get a lot for your money.
panky
Posted: 12:45am 14 Jun 2022
@k2backhoe
Just received a couple of these to play with - any hints on how you loaded MMBasic? Can't seem to get into the boot loader here.
Regards, panky
Edit: Forgot the "boot switch while powering up' bit.  MMBasic loaded and further testing started.
Edited 2022-06-14 11:28 by panky
Posted: 01:25am 14 Jun 2022
If there is no "Boot Select" button, in TeraTem try:-
"1200 baud which puts the Pico into firmware upgrade mode"
Manual page 5 near the bottom.
k2backhoe
Posted: 01:35am 14 Jun 2022
@panky
For others trying this board, make sure you have a good USB-C cable and try reversing it's orientation until things work right.  It takes a little fiddling, but worth it.
panky
Posted: 11:30pm 20 Jun 2022
@k2backhoe
A slightly modified version of Peter's Remote Thermostat program to run on the LilyGo T-PicoESP32C3. Note I don't have a temp module so those lines are commented out.
' LillyGo-Pico-ESP32 Thermostat v6
Option explicit
Option default integer
Const MaxLen=4096
Const max=20
' Global variables
Const quote=Chr$(34)
Const SSID$=quote+"xxxxxx"+quote
Const pw$=quote+"xxxxxx"+quote
Const crlf$=Chr$(13)+Chr$(10)
' Note crlf$ in html code below are purely to help in debugging
'  - they are ignored by the browser.
Const header$="<!DOCTYPE html>"
Const starttext$="HTTP"
Const pnf$="<html><body>Page not Found</body></html>"
Const t1$="<html><meta charset="+quote+"UTF-8"+quote+">"+crlf$
Const title$=t1$+"<head><title>Remote Thermostat</title></head><body>"+crlf$
Const ending$="</form></body></html>"+crlf$
Const form$="<form name='f1' method='get' action='D'>"+crlf$
Const h2$="<h2 align='left'>Remote Thermostat V6.0</h2>"+crlf$
Const code1$="Update Code: <input type='text' name='S' size='6' "
Const code$ = code1$+"value='000000'>
"+crlf$
Const tstart$="
<TABLE BORDER='1' CELLSPACING='0' CELLPADDING='5'>"+crlf$
Const heat$="<TR><TD>Heating</TD>"+crlf$
Const hon$="<TD BGCOLOR='#ff0000'> On</TD></TR>"+crlf$
Const hoff$="<TD BGCOLOR='#00ff00'>Off</TD></TR>"+crlf$
Const tend$="</TABLE>"+crlf$+"
"+crlf$
Const h3$="<TR><TD></TD><TD>Temperature</TD></TR>"+crlf$
Const s1$="<TR><TD>Current</TD><TD>"+crlf$
Const s2$="<TR><TD>Max</TD><TD>"+crlf$
Const s3$="<TR><TD>Min</TD><TD>"+crlf$
Const check1$="<input name='C' type='checkbox' value='R' "
Const check$ = check1$+"onClick='this.form.submit()'> Reset Max/Min"+crlf$
Const s4$="<TR>"+crlf$+"<TD>Thermostat</TD>"+crlf$
Const s5$="<TD><input name='R' type='radio' checked='checked' value='"
Const s6$="<TD><input name='R' type='radio' value='"
Const click$=" 'onClick='this.form.submit()'> "
Const degree$="C
</TD>"+crlf$
Const offstr$="Off
</TD>"+crlf$
Const onstr$="On
</TD>"+crlf$
Const ON=1
Const off=0
' Set up parameters
Const starttemp=20
'set lowest temperature on the thermostat select radio buttons
Const hysteresis=2 ' 2 tenths of a degree either side of the setpoint
Const waittime=1000 'wait time in readrequest before timeout
Const password$="123456" 'password to access change mode
Const dspin=22      'Pico GP17
Const relaypin=21   'Pico GP16
Dim integer webpage(4096\8) ' longstring with complete web page
Dim arg$(2,max) length 20
Dim integer inbuf(Maxlen\8) 'global input buffer
Dim integer IPDno 'global IPD numbers to ensure transmit is on correct IPD
Dim integer heater,currenttemp,maxtemp,mintemp,setpoint
Dim integer nparams
Dim mypage$ 'variables used by main loop only
Dim integer obuff(4096\8) 'buffer writes to the internet to optimise speed
Init:
' TEMPR START dspin,3 'measure temp to 0.0625 degree accuracy
mintemp=1000 'set to silly value to force reset if not saved
maxtemp=-1000
' currenttemp=Cint(TEMPR(dspin)*10)
VAR restore 'recover the setpoint and min and max temps if already saved
maxmin 'update the maximum and minimum and save them if changed
heater=off
Pin(relaypin)=heater
SetPin relaypin,dout
setpoint=Asc("E")
Pause 2000 'wait for ESP8266 to wake up afer power on
SetPin gp9,gp8,COM2
Open "com2:115200,4096" As #1
Close #1 'clear the buffer
SetPin gp9,gp8,COM2
If Not Command(0, "AT",obuff(), 500) Then End
If Not Command(0, "AT+RST",obuff(), 10000,"WIFI GOT IP") Then
'reset and checkFor valid connection
  Print "Set up WIFI on SSID: ",SSID$
  If Not Command(0, "AT+CWMODE=1",obuff(), 5000) Then End
  'set device mode (1=client, 2=AP, 3=both)
  If Not Command(0, "AT+CWLAP",obuff(), 30000) Then End
  'scan for WiFi hotspots
  LongString print inbuf() 'output the list of valid networks
  If Not Command(0,"AT+CWJAP="+SSID$+","+pw$,obuff(),20000,"WIFI GOT IP") Then
    End 'connect
  EndIf
  If Not Command(0, "AT+CIFSR",obuff(), 5000) Then End 'check IP address
EndIf
LongString Print inbuf()
If Not Command(0, "AT+CIPMUX=1",obuff(), 5000) Then End
If Not Command(0, "AT+CIPSERVER=1,80",obuff(), 5000) Then End
Print "Connected"
main:
updateheater
If ReadRequest(waittime) Then 'process HTML request
  mypage$=UCase$(parsehtmldata$(nparams))
  'parse the html request and get the Page requested
  If mypage$<>"" Then 'real request so do something
    If mypage$= "INDEX" Then
      drawpage
    ElseIf mypage$="D" Then
      If nparams<>0 Then 'we have parameters to process
        If arg$(0,0)="S" And arg$(1,0) = password$ Then
          If arg$(0,1)="C" And arg$(1,1)="R" Then
          'reset the max min to current
            maxtemp=currenttemp
            mintemp=currenttemp
            VAR save setpoint,maxtemp,mintemp
          EndIf
          If arg$(0,1)="R" Then
          'change the setpoint and update the heater if applicable
            setpoint=Asc(arg$(1,1))
            updateheater
          EndIf
        EndIf
      EndIf
      drawpage
    Else
      SendText pnf$+crlf$+crlf$'invalid page
    EndIf
    EndSend 'clear the write buffer and terminate the write
  EndIf
EndIf
End
Function parsehtmldata$(paramcount As integer)
Local a$,b$
Local integer buf(Maxlen\8)
Local integer inpos,startparam,processargs
paramcount=0
' a valid browser requesu will look like
'   GET /D?S=123456&C=R&R=C+
' once we get  the GET / we then ignore the D and look for the position
' of the ? then we extract the name pairs, each set seperated by &
inpos=LInStr(inbuf(),"GET /",1)
If inpos=0 Then
  parsehtmldata$=""
Else
  LongString mid buf(),inbuf(),inpos+5,1000
  inpos=LInStr(buf(),starttext$,1)
  If inpos>2 Then 'page request found
    inpos=inpos-2
    a$=LGetStr$(buf(),1,inPos)
    inpos=Instr(a$,"?")
    If inpos<>0 Then 'parameters found
      processargs=1
      parsehtmldata$=Left$(a$,inpos-1)
      a$=Mid$(a$,inpos+1)
        arg$(0,paramcount)=""
        arg$(1,paramcount)=""
        inpos=Instr(a$,"=")
        startparam=1
        arg$(0,paramcount)=Mid$(a$,startparam,inpos-startparam)
        startparam=inpos+1
        inpos=Instr(a$,"&")
        If inpos<>0 Then
          arg$(1,paramcount)=Mid$(a$,startparam,inpos-startparam)
          a$=Mid$(a$,inpos+1)
          paramcount=paramcount+1
        Else
          arg$(1,paramcount)=Mid$(a$,startparam)
          processargs=0
        EndIf
      Loop While processargs
    Else
      parsehtmldata$=a$
    EndIf
  Else ' no page requested
    parsehtmldata$="INDEX"
  EndIf
EndIf
End Function
Sub maxmin
Local integer update=off
If currenttemp>maxtemp Then
  maxtemp=currenttemp
  update=on
EndIf
If currenttemp<mintemp Then
  mintemp=currenttemp
  update=on
EndIf
If update Then VAR save setpoint,maxtemp,mintemp
End Sub
Sub updateheater
Local integer hcalc
If setpoint=Asc("L") Then
  Pin(relaypin)=ON
  heater=on
EndIf
If setpoint=Asc("A") Then
  Pin(relaypin)=OFF
  heater=oFF
EndIf
If setpoint>=Asc("B") And setpoint<=Asc("K") Then
  hcalc=(setpoint-Asc("B")+starttemp)*10 'setpoint temperature * 10
  hcalc = hcalc + hysteresis
  If currenttemp>=hcalc Then 'turn heating off
    Pin(relaypin)=OFF
    heater=oFF
  EndIf
  hcalc = hcalc - hysteresis - hysteresis
  If currenttemp<=hcalc Then 'turn heating on
    Pin(relaypin)=ON
    heater=oN
  EndIf
EndIf
End Sub
Sub drawpage
Local integer loopcounter,tempconvert
Local b$
sendText header$
sendText title$+form$+h2$+code$
sendText tstart$+heat$
If heater Then
  sendText hon$+tend$
Else
  sendText hoff$+tend$
EndIf
sendText tstart$
sendText h3$
b$=s1$+outtemp$(currenttemp)+degree$
b$=b$+s2$+outtemp$(maxtemp)+degree$
b$=b$+s3$+outtemp$(mintemp)+degree$
sendText b$
sendText tend$
sendText check$
sendText tstart$
sendText s4$
For loopcounter=Asc("A") To Asc("L")
  If loopcounter=setpoint Then
    sendText s5$+Chr$(loopcounter)
  Else
    sendText s6$+Chr$(loopcounter)
  EndIf
  sendText click$
  tempconvert=loopcounter-Asc("B")+starttemp
  If loopcounter>Asc("A") And loopcounter<Asc("L") Then
    sendText Str$(tempconvert,2)+degree$
  EndIf
  If loopcounter=Asc("A") Then sendText offstr$
  If loopcounter=Asc("L") Then sendText onstr$
Next loopcounter
sendText tend$
sendText ending$+crlf$+crlf$
End Sub
Function outtemp$(t As integer)
Local integer tenths=t Mod 10
Local integer units= t\10
outtemp$=Str$(units,3)+"."+Chr$(tenths+48)
End Function
Sub EndSend
Local b$
Pause 25
b$="AT+CIPSEND="+Chr$(IPDno+48)+","+Str$(LLen(obuff()))
'send anything still in the buffer
If Not Command(0,b$,obuff(), 500,">") Then
  If LInStr(inbuf(),"link is not valid") Then Exit Sub
EndIf
If Not Command(1, b$, obuff(),500) Then End
Pause 25
If Not Command(0, "AT+CIPCLOSE="+Chr$(IPDno+48),obuff(), 500) Then
  If LInStr(inbuf(),"UNLINK") Then
    LongString clear obuff()
    Exit Sub
  Else
    End
  EndIf
EndIf
End Sub
Sub SendText(a$)
Local b$
If Len(a$)+LLen(obuff())< 2048 Then
  'add the new string to the output buffer
  LongString append obuff(),a$
Else 'too big to fit so send the current output buffer
 Pause 25
  If Not Command(0,b$,obuff(),1000,">") Then
  EndIf
  If Not Command(1, b$, obuff(),1000) Then End
EndIf
End Sub
Function ReadRequest(timeout%) As integer
Local fv$ = "favicon",cf$="CONNECT FAIL"
ReadRequest=0
LongString Clear inbuf()
Timer =0
Do While Timer<timeout% And Loc(#1)=0
If Timer>=timeout% Then Exit Function
Do While Loc(#1)<>0
  LongString append inbuf(),Input$(Min(255,Loc(#1)),#1)
  Pause 10
Print "browser request - ";
If (Not LInStr(inbuf(),fv$,0)) And (Not LInStr(inbuf(),cf$,1)) Then
  ReadRequest=1 'junk the favicon requests and disconnects
EndIf
If LInStr(inbuf(),"IPD,0",1) Then IPDno=0
If LInStr(inbuf(),"IPD,1",1) Then IPDno=1
End Function
Function Command(mode, AT$, outdata%(), timeout%, other$) As integer
'send a command And wait For the answer
Local i%=0,j%,ex%=0
Local a$
Command=0
If mode=0 Then
  Print #1,AT$+crlf$;
Else
  LongString print #1,obuff();
EndIf
Timer =0
i%=0
  If Timer>timeout% Then
    ex%=0
    Exit
  EndIf
  j%=Loc(#1)
  If j%>0 Then
    i%=i%+Min(255,j%)
    LongString append inbuf(),Input$(Min(255,j%),#1)
    If LLen(inbuf())>4 And other$="" Then
      If LInStr(inbuf(),"OK",1) Then
        ex%=1
        Exit
      EndIf
    EndIf
    If LLen(inbuf())>7 Then
      If LInStr(inbuf(),"ERROR",1) Then
        ex%=2
        Exit
      EndIf
    EndIf
    If LLen(inbuf())>Len(other$)+2 Then
      If LInStr(inbuf(),other$,1) Then
        ex%=3
        Exit
      EndIf
    EndIf
  EndIf
Select Case ex%
  Case 0
    Print "Timeout : "+AT$
  Case 1
    Command=1
  Case 2
    Print "ERROR : "+AT$
  Case 3
    Command=1
End Select
End Function
Also, the html source. In the original, there appeared to be some unclosed <TR></TR> sequences so I broke out and captured the html for my own education - might be useful if anyone wants to play with it. I put in some CR LF sequences to make it a little easier to see what was happening (note that html ignores CR LF).
<!DOCTYPE html><html><meta charset="UTF-8">
<body>
Update Code: <input type='text' name='S' size='6' value='000000'>
</TR>
</TABLE>
<TR>
<TD></TD>
</TR>
<TR>
<TD>Current</TD>
<TD>  0.0C
</TD>
<TR>
<TD>Max</TD>
<TD>
 0.0C
</TD>
 0.0C
</TD>
</TABLE>
<input name='C' type='checkbox' value='R' onClick='this.form.submit()'> Reset Max/Min
<TR>
<TD>Thermostat</TD>
<TD><input name='R' type='radio' value='A 'onClick='this.form.submit()'> Off
</TD>
<TD><input name='R' type='radio' value='B 'onClick='this.form.submit()'> 20C
</TD>
<TD><input name='R' type='radio' value='C 'onClick='this.form.submit()'> 21C
</TD>
<TD><input name='R' type='radio' value='D 'onClick='this.form.submit()'> 22C
</TD>
<TD><input name='R' type='radio' value='E 'onClick='this.form.submit()'> 23C
</TD>
<TD><input name='R' type='radio' value='F 'onClick='this.form.submit()'> 24C
</TD>
<TD><input name='R' type='radio' value='G 'onClick='this.form.submit()'> 25C
</TD>
<TD><input name='R' type='radio' checked='checked' value='H 'onClick='this.form.submit()'> 26C
</TD>
<TD><input name='R' type='radio' value='I 'onClick='this.form.submit()'> 27C
</TD>
<TD><input name='R' type='radio' value='J 'onClick='this.form.submit()'> 28C
</TD>
<TD><input name='R' type='radio' value='K 'onClick='this.form.submit()'> 29C
</TD>
<TD><input name='R' type='radio' value='L 'onClick='this.form.submit()'> On
</TD>
</TABLE>
</form>
</body>
</html>
Edited 2022-06-21 10:08 by panky
Tinine
Posted: 01:39pm 11 Jul 2022
Just hunted for this thread because I keep meaning to ask panky if he had the same problem as the OP in keeping MMBasic present on the chip
My Lilygo is not due until August 29th but I just found the thread and "plonk". Small package dropped on my desk, clearly from AE. Yup, my Lilygo
Firmware loaded with no issues and it's sitting here, running @378MHz
Note to Mixtel90: That comment you made regarding the antenna connector? The display is only held on with tape. The idea is that you pull it away from the board when you install in an enclosure.
Craig
Posted: 03:33pm 11 Jul 2022
My comment about the connector was that it's too close to the fixing hole. If you use a metal screw or mounting pillar there then you'll almost certainly de-tune the antenna to some extent. You can get round it by using a nylon pillar and screw, but I bet that isn't in the instructions. :) Mind you, that is the ground end of the antenna so the effect may not be too bad. The other end is the "hot" end - you don't want to get anything metallic near that or you may have no signal at all.
I had another comment about the display being too close to any front panel. So you can pull the display off and mount separately it with no visible means of support? That's kinda interesting. lol
Tinine
Posted: 04:04pm 11 Jul 2022
Yeah, an enclosure would be a 3d print job:
Craig
Tinine
Posted: 04:05pm 11 Jul 2022
Double post
Edited 2022-07-12 02:07 by Tinine
k2backhoe
Posted: 01:51am 12 Jul 2022
Mixtel raises some really good points about antenna detuning.  I was initially enthralled with this board because it was a really cheap/small way to have display functionality with MMBasic.  Since then many other alternatives have arrived, so don't be overly swayed by my initial enthusiasm.
Tinine, neat catch on detaching display.  I don't 3-D print but I kludge one-of-a-kind stuff with hot glue and I will try detaching this.
k2
Tinine
Posted: 04:26am 12 Jul 2022
  k2backhoe said  Mixtel raises some really good points about antenna detuning.  I was initially enthralled with this board because it was a really cheap/small way to have display functionality with MMBasic.  Since then many other alternatives have arrived, so don't be overly swayed by my initial enthusiasm.
k2
Well, there's been a bit of chat about Picomite-WiFi and I have very little experience with WiFi....Within 20 min of first powering up, I was connected
I like easy stuff.
It runs happily at 378MHz.
I have a guy here who owns nine 3d printers and #10 ships out this month....but he is short of things to print
He's chomping at the bit to print stuff for me
Craig
Tinine
Posted: 05:38pm 12 Jul 2022
Meh...fallen out of love with this thing. Bluetooth Classic is not enabled and I'd need to jump through all kinds of hoops to do that.
Display has an offset problem...screw-it. Gonna stick with the no-frills PGA2040
Craig
panky
Posted: 02:53am 15 Jul 2022
For those wishing to use Annex RDS Basic on the ESP in this module - please see RDS Forum here
Cheers,
Doug.
panky
Posted: 02:58am 15 Jul 2022
  Tinine said  ...
Display has an offset problem ...
Craig
You need to set the LCD driver as
OPTION LCDPANEL ST7789_135, LANDSCAPE, gp1, gp6, gp5, gp4
Cheers, Doug.
