Local Time 05:56 16 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Bit of a TEMPR() tantrum...
Tinine
Posted: 02:26pm 07 Jun 2022
Works great on first run-through but after breaking-out and re-starting, I get "Error : Pin 21 is in use"
Am only able to run again after power-cycling the PicoMite.
Should I be doing some form of reset?
Craig
Posted: 02:38pm 07 Jun 2022
What's your code? Picomite? OPTION LIST?
Tinine
Posted: 02:50pm 07 Jun 2022
Yeah it's the PicoMite and the only OPTION is the CPUSPEED 250000K
do
   timer =0
   tempr start GP16
   do
       if timer > 3000 then exit do
   loop
   PRINT "Temperature: ",TEMPR(GP16)
loop
Posted: 03:07pm 07 Jun 2022
You are starting a background transaction that locks the pin used and then Ctrl-Cing out before completing the transaction with the tempr function. This is causing the problem. However, I suspect you are also running old firmware as this issue was circumvented in 5.05.04
You may not need TEMPR START.
a=TEMPR(sensor_pin) should be ok.
I suspect TEMPR START will lock the pin until you use TEMPR STOP
EDIT:
Peter keeps beating me to replies like this. :)
Edited 2022-06-08 01:09 by Mixtel90
Tinine
Posted: 03:30pm 07 Jun 2022
Thanks guys..
I only pulled this PicoMite out of the drawer after smoking the other. Didn't think to check the F/W version and my manual must be out of date because I was looking for something like TEMPR STOP.
Craig
Tinine
Posted: 03:37pm 07 Jun 2022
Another question:
I stick the probe in my mug o' tea and every reading is valid. However, as it drops to room temp, I get the occasional "1000" reported. I'm guessing that the probe didn't have enough time or something(?)
Craig
Tinine
Posted: 03:58pm 07 Jun 2022
  matherp said  You are starting a background transaction that locks the pin used and then Ctrl-Cing out before completing the transaction with the tempr function. This is causing the problem. However, I suspect you are also running old firmware as this issue was circumvented in 5.05.04
Hmmm, 5.0703 and still have the problem. Even with this orderly exit:
do while inkey$<>"":loop
do
 timer =0
 tempr start GP16
 do
 loop
loop until inkey$<>""
Craig
Posted: 04:56pm 07 Jun 2022
Do while Inkey$<>""
print "Temperature: ";tempr(gp16)
pause 3000
loop
Just using TEMPR() will block interrupts for 200ms. I assume that was what you are trying to avoid?
Returning 1000 indicates a read error.
Posted: 05:09pm 07 Jun 2022
  Quote  Hmmm, 5.0703 and still have the problem
  Quote  However, I suspect you are also running old firmware as this issue was circumvented in 5.05.04
Posted: 05:11pm 07 Jun 2022
Works for me:
Const tpin=29
Do While Inkey$<>"":Loop
Timer =0
TEMPR START tpin
  If Timer > 3000 Then Exit
Print "Temperature: ",TEMPR(tpin)
Loop Until Inkey$<>""
> RUN
Temperature:     26.5
Temperature:     26.25
> RUN
Temperature:     25.75
Temperature:     25.5
Temperature:     25.5
> ?mm.ver
5.070503
Tinine
Posted: 05:12pm 07 Jun 2022
  Mixtel90 said
Do while Inkey$<>""
pause 3000
loop
Well, I found the following in the manual:
TEMPR START GP15
< do other tasks >
PRINT "Temperature: " TEMPR(GP15)
I am monitoring a pushbutton at the same time and would prefer it to be instantly responsive.
Not really a problem because nobody will be exiting the finished program....well not intentionally
Craig
Posted: 05:22pm 07 Jun 2022
A bit under 200ms per TEMPR read for 5 reads:
> timer=0:?tempr(29),tempr(29),tempr(29),tempr(29),tempr(29),timer
25.5    25.5    25.5    21.25   21.25   848.905
Posted: 05:27pm 07 Jun 2022
This is how I would do it
TEMPR START gp2
SetTick 1000,myint
'process whatever
Sub myint
Print TEMPR(gp2)
TEMPR START gp2
End Sub
This can be interrupted with crtl-C and restarted with no issue on 5.07.04
Edited 2022-06-08 03:28 by matherp
Tinine
Posted: 06:21pm 07 Jun 2022
  matherp said  This is how I would do it
TEMPR START gp2
SetTick 1000,myint
'process whatever
Sub myint
Print TEMPR(gp2)
TEMPR START gp2
End Sub
Yay    . Many thanks, Pete.
Craig
Tinine
Posted: 06:39am 08 Jun 2022
  lizby said  A bit under 200ms per TEMPR read for 5 reads:
I probably have some kind of syndrome
Having to double-stab a button due to a slow scan-time would drive me nuts
Hey, these waterproof sensors are pretty darned cool
Craig
Posted: 01:58pm 08 Jun 2022
  Tinine said  Hey, these waterproof sensors are pretty darned cool
They are. I've been using one to get the outside temperature for about 8 years.
But noting the topic on fakes/copies/rejects, just don't expect accuracy or consistency between sensors, since I doubt that you can be sure that any if these waterproof DS18B20s are genuine.
Edited 2022-06-09 00:00 by lizby
Tinine
Posted: 06:47pm 08 Jun 2022
No kidding! I plan to calibrate which is a PITA I could do without
Client has gotten really serious about these seat heaters...tried to price my way out of the job but that didn't work   Looks like my first order is 200 units and now they're already talking V2.0 to include "a fan"
Do you get "1000" (bad reading) at the lower temperatures?
Craig
Posted: 06:52pm 08 Jun 2022
According to the TEMPR() function in the 5.07.03 manual, yep.
(I really must print a newer one out...)
Posted: 06:58pm 08 Jun 2022
I got one of these to play with for heatsink temperature monitoring, but it needs an analogue input.
https://www.bitsbox.co.uk/index.php?main_page=product_info&cPath=302_307&products_id=2095
Look at the price though. :)
