Local Time 05:56 16 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Malwarebytes terminates and quarantines MMbasic.exe
Paul_L
Posted: 05:55am 13 Jun 2022
I have Malwarebytes setup as my primary antivirus with its Web Protection, Malware & PUP Protection, Ransomware Protection and Exploit Protection all turned on.
Malwarebytes uses heuristic observation of the behavior of programs to detect malicious stuff.
It terminates and quarantines the MMBasic.exe extracted from 2022-04-22_V5.07.03b10 MMBasic Windows beta.zip. It thinks that MMBasic is being naughty.
If I go into the Real-Time Protection settings of Malwarebytes and turn Malware & PUP Protection off it then does not halt or quarantine MMBasic.exe, but Windows Security then pops up a warning that both Malwarebytes and Windows Defender malware protection is turned off. Windows Security itself does not detect that Malware & PUP protection is insufficient.
Malwarebytes has no way to create an exception for MMBasic.exe.
What the heck is MMBasic doing that Malwarebytes does not like. Must I leave Malware & PUP Protection off in order to run MMBasic.
Paul in NY
Posted: 06:25am 13 Jun 2022
This doesn't fix it then?
Tinine
Posted: 06:42am 13 Jun 2022
I simply don't bother with that stuff:
Reboot Restore Rx
Reboot Restore Rx prevents any changes made on your drive(s) by restoring a saved baseline every time the PC boots up.
It is designed for small public access computing environments such as classrooms, libraries, kiosks, and internet cafes.
Even when users download files, viruses, malware, or even try to delete registry keys, Reboot Restore Rx will restore the PC back to your desired state.
From here...
Your data goes elsewhere (DropBox in my case).
Craig
Posted: 11:01am 13 Jun 2022
After having no issues with MMB4W, Malwarebytes decided to start quarantining it. I did what Mick's article suggests--added it to the "Allow" set.
