Forum Index : Microcontroller and PC projects : CMM default Drive
| Chrisk Senior Member Joined: 21/12/2014 Location: AustraliaPosts: 137 |
Hi Guys Currently when I connect my laptop to my CMM and enter via Tera Term I find that I am connected to the A: drive. What is the correct instruction syntax to have this default to the B: drive (SD Card). With the autorun file in B: the file is not found after a power fail. I have no idea how this changed. I tried the Drive instruction but it doesn't seem to work. This below is attempting to change the default drive in a Explore 64 > DRIVE "B:" Error : Unknown command > ? MM.DRIVE Error : MM.DRIVE already declared Is this instruction the same for my Explore 64 and CMM. Chrisk |
| phil99 Guru Joined: 11/02/2018 Location: AustraliaPosts: 3379 |
MM+ manual pages 6 & 19 for the Explore 64. I think drive letters are not supported or needed as it can access only one card. Though there is mention of limitations with exFAT causing paths to just show as A:/ so perhaps A:/ can be an optional prefix of paths. . Edited 2022-06-26 18:23 by phil99 |
No. The Explore 64 does not have "drives". So you cannot use "A:", DRIVE, etc. On the original Colour Maximite you can use drives and the the default on power up should be "B:". Do you have an SD card inserted? Perhaps you have a hardware fault in the SD card connector or a faulty card. You could try creating the file AUTORUN.BAS with a single line in it saying DRIVE "B:" and saving that file to drive "A:". But that should not be necessary. Geoff Geoff Graham - http://geoffg.net |
Thanks Phil99 and Geoffg. I suspect you might be right Geoff as I was updating the wiring and maybe something happened that I wasn't aware of. I need to download this month's data at the end of the month and will check it out then. Thankyou both for your quick replies. Chrisk |
