Local Time 04:06 16 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Looking For - I2C Scanner - Picomite
pwillard
Posted: 02:43pm 29 Jun 2022
Is there a version of an I2C Scanner that works on Picomite?  Maybe "Search" has failed me?
CaptainBoing
Posted: 02:51pm 29 Jun 2022
try this
you might have to tweak it a bit to define the I2C pins etc as the pico has no defaults
pwillard
Posted: 02:56pm 29 Jun 2022
Lifesaver!
' i2cdetect like program
' Set Pins!
SetPin gp0, gp1, I2C
' Open first I2C
I2C open 100, 200
' Prep table
Print "     0  1  2  3  4  5  6  7  8  9  A  B  C  D  E  F"
' loop col/row
For y=0 To 7
Print Hex$(y,2);": ";
For x=0 To 15
  addr = y*16+x               ' calc address
  I2C write addr, 0, 1, &H00  ' write zerp to that adress
  If MM.I2C=0 Then            ' check for errors
    Print Hex$(addr,2);" ";   ' found one!
 Else
   Print "-- ";               ' nothing here..
 EndIf
Next x
Print
Next y
I2C close  ' clean up
results in:
00: 00 -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
01: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
02: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
03: -- -- -- -- -- -- -- 37 -- -- -- -- -- -- -- --
04: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
05: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
06: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
07: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
Which is great!  Thanks.
