Forum Index : Microcontroller and PC projects : 3,3 V for the pico Ps2 keyboard
| Plasmamac Guru Joined: 31/01/2019 Location: GermanyPosts: 620 |
Hi, I testet my keyboard with 3,3 V. Its working with 3,3v. Have you a keyboard which works with 3,3v ? Anyone can confirm and shows the brand here ? Unfortunately my keyboard has no label in the back. Gtx Plasma |
| LandBoardsLLC Newbie Joined: 04/06/2022 Location: United StatesPosts: 19 |
I've tried 3.3V operation with 5 or 6 keyboards. Most worked. I had 2 identical Microsoft Natural keyboards where one worked and the other didn't. - Doug at Land Boards LLC |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 11854 |
I think this is the issue. Any recommendation could not guarantee all keyboards of that make/model would behave the same. |
| phil99 Guru Joined: 11/02/2018 Location: AustraliaPosts: 3379 |
The only keyboard that I have that requires 5V power (a very old Hewlett Packard) works perfectly with the pullups going to 3.3V, so it does not need level shifters. Its a matter of testing before deciding if you can omit the level shifters. |
| Mixtel90 Guru Joined: 05/10/2019 Location: United KingdomPosts: 9134 |
The only reason I'd leave out the level shifter on my boards now would be for miniaturisation. As a *minimum* I'd fit 270R series resistors and Schottky diodes and parallel 10k pull-ups to 3V3 because someone, somewhere will plug in a non-standard keyboard that has its own internal pullups to 5V (as do many mice). This arrangement isn't perfect, but it will give a degree of protection. Mick Zilog Inside! nascom.info for Nascom & Gemini |
