Local Time 23:10 15 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : send VGA monitor to sleep (PicomiteVGA/MAXIMITE)
electricat
Posted: 02:20pm 27 Aug 2022
VESA has defined a standard method for computer to tell monitor when to go to power saving mode. This power saving mode is controlled by changing the sync signals OFF
H-sync    Off / V-sync    Off  / Power level <8W
Read more at: https://www.epanorama.net/documents/pc/vga_bd15.html
I had idea once. Power auto saving feature might be useful OPTION for PicomiteVGA/MAXIMITE. For example send monitor to sleep after keyboard inactivity for 10/30/60 mins ??
Just an idea.
My MMBasic 'sand box'
Posted: 04:41am 29 Aug 2022
Interesting idea.  I could use that, as I have security/emergency systems that use a VGA monitor, and they are on 24/7/365 till they die.  But as replacement LCD screens are a dime a dozen for 2nd hand smaller ones, generally "Saving" a screen is something of a non-issue these daze, as you just throw the dead one on the scrap pile, and plop another one in there for very little cash.  Unlike in days gone past, where a replacement CRT or LCD screen would set you back several hundred bucks.
It would be easy enough to simply have a DPDT relay or similar that you route your sync signals though, and the MM could then switch the relay off using a SETTICK timer, which would then shut off the monitor, but is it REALLY worth the effort I guess is the thing.
Posted: 06:21am 29 Aug 2022
Put series resistors on the sync lines followed by a N-channel MOSFET to ground. Put the gates onto a single GPIO pin, with a resistor to ground (so they will normally turn off). Raise GPIO pin, monitor shuts down. :)
You might even get away with series resistors then Schottky diodes to a common GPIO pin, in which case it's pin low-monitor off. It should pull the sync signals low enough.
Edited 2022-08-29 16:23 by Mixtel90
electricat
Posted: 11:28am 29 Aug 2022
Mixtel90,
Sure! Many hardware ways there might come to mind. Analog timer, PIR, light sensor, latching button etc. etc.
But if we can save GPIO and just stop/start generating H-sync / V-sync from second PicomiteVGA core??
One could use OPTION VGAOFF 10/30/60 (or free number) and enjoy such energy/monitor saving functionality on pcb already they have without additional modifications.
Edited 2022-08-29 21:29 by electricat
Posted: 11:42am 29 Aug 2022
H_Sync and V_Sync are controlled by a PIO program and there is no easy way to turn them on and off so this won't be happening - sorry
