Forum Index : Microcontroller and PC projects : MM.Devices$
| Lightrock Newbie Joined: 19/05/2014 Location: AustraliaPosts: 26 |
I am modifying a program for a '170 Micromite to run on a Picomite. I intended to use to MM.DEVICES$ command to confirm which device was connected. I could not get it to work so I tried entering the command from the command line but there was no response. I also tried the command on a 44 pin Micromite with no luck. I tried other commands such as MM.INFO$(LCDPANEL), MM.VER and they worked as expected. ? MM.DEVICES$ > ? MM.DEVICES Error : MM.DEVICES Different type already declared > ? MM.info$(LCDPANEL) ILI9341 > What am I missing? Roy |
| lizby Guru Joined: 17/05/2016 Location: United StatesPosts: 3879 |
You have an "S" at the end of your command; it's "?mm.device$" PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on FOTS |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 11852 |
Nothing, but you are adding an S ? MM.DEVICE$ |
Thanks everyone. Reading too much into the command description. |
