Local Time 19:41 15 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Picomite and ST7735 128*160 display
KenH
Posted: 01:20pm 20 Oct 2022
Hello
Update: Just noticed the POKE DISPLAY command [,data1] [,data2] [,datan]
command, so I guess that will solve my problem. Giving a try now!
No luck, obviously "barking up the wrong tree!"
I have just received several ST7735 128x160 displays marked 1.8 TFT SPI 128*160 V1.1 When used in portrait mode the display is shifted 2 pixels to the left and one pixel up leaving a border at the bottom and right of random pixels. I have tried both PicoMiteV5.07.04 and PicoMiteV5.07.05RC8.
Option System SPI GP10,GP11,GP12
Option LCDpanel ST7735, RP,GP8,GP15,GP9
I have had several of these displays previously which have not exhibited this problem. I am aware that some of the drivers for the Micromite and Picomite have extra parameters to allow alignment of the display to overcome similar problems. Unfortunately, there does not appear to be this facility with the Picomite ST7735 driver.
I am assuming that the ST7735 registers CASET at 2Ah and RASET at 2Bh need to have an offset added, but as the Picomite does not allow access to the system SPI bus, I cannot find a way to achieve this.
Any suggestions welcome.
Best wishes
Ken
Edited 2022-10-21 01:55 by KenH
Doktorn
Posted: 08:43pm 20 Oct 2022
Hi
Had the same problem with my ST7735, solved with:
Poke DISPLAY HRES 162
Poke DISPLAY VRES 130
Lasse
KenH
Posted: 08:59am 21 Oct 2022
That's absolutely great. Thank you. The random pixels disappear as soon as you do a CLS.
I am currently missing the first 2 pixels on the left-hand edge but can easily work through my program and add an offset - so that's easily solved.
Thanks again for your reply and help.
Best wishes
Ken
