Local Time 14:25 15 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : IC orientation
palcal
Posted: 02:52am 27 Dec 2022
I am building a Buck Boost converter, Silicon Chip June 2022. One of the ICs is a 1NA282AIDR  SOIC-8, I want to make sure of the orientation, the layout diagram just shows pin 1 and the picture of the board is not clear. This IC is shown with pin 1 top right. I could not get a good picture of the chip even using super macro and it does not have any marking to indicate pin 1. Looking at the chip with the writing the right way up it does have a line market top to bottom on the left hand side. Can I assume that pin one is bottom left in which case the chip will mount upsidedown on the PCB.
Turbo46
Posted: 03:11am 27 Dec 2022
The board layout on page 45 shows a grey line down one side indicating that pin one is top left with the line running down the left side. Does that help?
Bill
palcal
Posted: 03:55am 27 Dec 2022
I saw that but on my chip there is a stripe of 5 thin lines but the lines run at 90 degrees to the one marked in the layout. So if that were my chip in the layout the line would run from pin 1 to pin 8. I don't feel safe mounting it and Silicon Chip are probably on holidays but I will email them anyway.
Posted: 04:09am 27 Dec 2022
Yes P45 shows the stripe going from pin 1 to pin 4, TI data sheet doesn't show the stripe but google images seems to suggest it goes from pin 1 to pin 8.
Perhaps there is an errata in a later issue - often the last page.
Posted: 04:19am 27 Dec 2022
G’day Palcal, All,
In almost all ICs if you have the letttering in correct orientation the pin 1 will be the bottom left.
If you want to make sure.
Looking at the data sheets it appears that pin 4 in not connected (NC) try buzzing out to other pins. The one that’s pin 8 will probably have some connectivity to other pins but pin 4 will not.
To identify the PCB layout, it appears that pins 1 and 8 connect across a current sense resistor so simply determine the orientation by where the sense resistor connects to.
Turbo46
Posted: 04:31am 27 Dec 2022
I found this which looks something like you describe.
https://www.ebay.com.au/itm/302556799276
I can only make out one line in the photo. There are similar modules listed below too.
Bill
palcal
Posted: 04:34am 27 Dec 2022
Well I'll mount it, but like I said it is unusual for their designs to have one chip upsidedown, larger pin count ones sometimes vertical but not upside down.
Posted: 04:49am 27 Dec 2022
"https://www.ebay.com.au/itm/302556799276"
That pic shows clearly the stripe is next to the current shunt, so it it goes from 1 to 8 as they connect to the shunt.
Turbo46
Posted: 04:50am 27 Dec 2022
I'm worried that you'll blame me if it's wrong now
But look at the picture on page 40 it shows a line across the top and a dot on the PCB to indicate pin 1 at the left end of that line. Looking closely at the other picture I can sort of see a line across the top.
Normally they have a little illustration of the components on the schematic but they've missed this one.
Bill
Justplayin
Posted: 05:07am 27 Dec 2022
Pin 2 of the chip is ground.  Do a continuity check on the two pads that might be ground to a known ground location on the board.  That will tell you the proper orientation of the chip.
palcal
Posted: 06:01am 27 Dec 2022
Looking at the EBay picture I'm happy that I have it the correct way around.
Thanks all.
TrevorH
Posted: 01:12pm 27 Dec 2022
I think the chip is "INA282Axxx" NOT "1NA282Axxx".
See https://www.hitechcat.com/products/ina282aidr
bottom pin is 1, bevelled side is 1-4,  hope this helps.
its the way I see it anyway.
palcal
Posted: 09:22pm 27 Dec 2022
Thanks for that Trevor, you are correct. The chip just has 282 but looking closely at the magazine it is an "I". It does have the stripe on the left and looking under the microscope it does have a bevel though not very pronounced. I just assumed a one because a lot of other diodes begin with "1N"
All good, thanks.
palcal
Posted: 10:33pm 27 Dec 2022
Thanks everyone finished the board and all works as it should.
BTW I'm using it as a DC-DC battery charger.
