Local Time 12:31 15 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PULSE on the PicoMite
OA47
Posted: 09:18am 19 Jan 2023
Is the description of the PULSE command still accurate with the PicoMite given it has a much higher frequency?
The minimum is 5µs at 40MHz to 40µs at 5MHz
OA47
Posted: 11:00am 19 Jan 2023
Current manual p115.
"For a pulse of less than 3 ms the accuracy is ± 1 µs.
For a pulse of 3 ms or more the accuracy is ± 0.5 ms.
A pulse of 3 ms or more will run in the background. Up to five
different and concurrent pulses can be running in the background and
each can have its time changed by issuing a new PULSE command or it
can be terminated by issuing a PULSE command with zero for 'width'."
Edit
Using a PIO program and maximum CPU speed you can make much shorter pulses.
Edited 2023-01-20 07:19 by phil99
