Forum Index : Microcontroller and PC projects : RP2040 DMA Hack Makes Another ‘CPU Core’
Saw this here |
| Mixtel90 Guru Joined: 05/10/2019 Location: United KingdomPosts: 9128 |
A "because it can be done" project. :) Very neat but probably of very limited use. Mick Zilog Inside! nascom.info for Nascom & Gemini |
there may be the odd niche where it could be useful. for instance, if you wanted a small auxiliary processor to handle USB communications with zero interaction with the two main cores. a bit like how the 16F1455 processor handles USB for the MX170/470 on Explorer boards. cheers, rob :-) |
| JohnS Guru Joined: 18/11/2011 Location: United KingdomPosts: 4378 |
Good grief! How... er, bizarre? John |
It goes to show the flexibility of the RP2040 architecture. I suspect this possibility wasn't part of the original design. Usually someone will find a way to make things do what they weren't intended to. :) Mick Zilog Inside! nascom.info for Nascom & Gemini |
