Local Time 11:23 15 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : BME280 'horrible' expression.
paceman
Posted: 04:57am 24 Jan 2023
Back in 18/2/2016 here Peter deciphered the "ridiculous" (his expresion) programming interface for the BME280 Bosch pressure sensor and wrote MMBasic code for it. I've been running it successfully on the PicoMite for some time but whenever I want to modify the main program I have trouble loading one very long line in the code from Teraterm using either AUTOSAVE or XMODEM. Here's the culprit line:
v_x1=(((((adc_H<<14)-((H4)<<20)-(H5*v_x1))+16384)\ q(15))*(((((((v_x1*H6)\ q(10))*(((v_x1*H3)\ q(11))+32768))\ q(10))+2097152)*H2+8192)\ q(14)))
I've tried to reduce it to shorter lines using some dummy variables but it's not obvious where the line can be 'broken'. I also wonder whether there's a problem with the brackets because by my count there are 23 of "(" but only 22 of ")". It runs properly though so maybe the spare or missing one is redundant.
Can someone have a go for me to reduce this line to say three lines or so.
panky
Posted: 06:47am 24 Jan 2023
@paceman
The following may be helpful.
' pseudo code showing indentation
v_x1=(
                (adc_H<<14)-
                       (H4)<<20
                       (H5*v_x1)
             )+16384
          )\ q(15)
                         (v_x1*H6)\ q(10)
                            (v_x1*H3)\  q(11)
                         )+32768
                   )\ q(10)
                )+2097152
             )*H2+8192
          )\ q(14)
' end pseudo code
' original split into 3 shorter segments
'  - Note: you need two temporary variables v-tmp1 and v-tmp2
v-tmp1= ((((adc_H<<14)-((H4)<<20)-(H5*v_x1))+16384)\ q(15))
v-tmp2= (((((((v_x1*H6)\ q(10))*(((v_x1*H3)\ q(11))+32768))\ q(10))+2097152)*H2+8192)\ q(14))
v_x1 = v-tmp1 * v-tmp2
The number of opening and closing parenthesis is correct at 23 for both.
The only anomaly I can see is in the second statement (v-tmp2), which I have highlighted in red -  I don't know if the order of the multiply followed by addition is correct (just don't know enough about the BME280)
Doug.
paceman
Posted: 11:03am 24 Jan 2023
Doug, you're my saviour. That works perfectly, or at least it gives the same pressure as Peter's original code so that'll do me!
I counted the opening/closing brackets twice and came up with the 23/22 split both times. Just blind somewhere I guess but your pretty 'staircase' is nice and I hadn't thought of doing that. The order of the multiply and divide was my problem too so I think we'll stick with your solution that works. It's a horrible expression though isn't it, I'm glad Peter sorted it so I didn't have to!
Greg
