Local Time 11:24 15 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Picomite console via gpio UART instead of USB
Vampire05
Posted: 07:14am 26 Jan 2023
Hi guys,
Is it possible to use the picomite console via gpio UART instead of USB? I would like to use ESPTerm (https://github.com/espterm/espterm-firmware).
Best regards
Artem
Posted: 07:25am 26 Jan 2023
Manual p80
OPTION SERIAL CONSOLE
uartapin, uartbpin [,B]
? Specify that the console be accessed via a hardware serial port
(instead of virtual serial over USB).
‘uartapin’ and ‘uartbpin’ can be any valid pair of rx and tx pins for
either COM1 or COM2. The order that they are specified is not
important. The speed defaults to 115200 baud but can be changed
with OPTION BAUDRATE. Adding the "B" parameter means
output will go to "B"oth the serial port and the USB.
DISABLE
Revert to the normal the USB console.
These commands must be run at the command prompt (not in a
program).
Vampire05
Posted: 07:31am 26 Jan 2023
This is embarrassing. I have read the instructions 100 times, but overlooked the point (probably due to lack of interest at the time)...
Vampire05
Thank you phil
