Local Time 10:21 15 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : RGB(x,y,z) - Red and Blue swapped?
Nimue
Posted: 05:36pm 05 Feb 2023
PicoMite MMBasic Version 5.07.06
OPTION SYSTEM SPI GP10,GP11,GP28
OPTION COLOURCODE ON
OPTION LCDPANEL ST7735, RLANDSCAPE,GP8,GP12,GP9,GP13
Using: Waveshare 1.44
Link to Waveshare board
The panel is a ST7735S -- but if I initialise with ST7735S the screen resets to random noise.  Using ST7735 seems to work.  The panel is 128x128.
Interestingly sometimes when the board fires up, there is a x1 pixel row at the bottom showing a random selection of colours which only goes away if I OPTION RESET and setup the LCDPANEL again.
The LCD panel works fine - coordinate wise.  But RGB(100,0,0) draws in BLUE and RGB(0,0,100) draws in RED.   RGB(0,100,0) draws in green as expected.
Have I lost the plot or am I missing something?
N
Nimue
Posted: 05:46pm 05 Feb 2023
Update --- the following sequence is reporducabel (at least for me).
Option RESET
-- Works Fine
Power cycle the Pico >>> Bottom row of random pixels.
Then:
Option RESET
Still garbled bottom row.
Power cycle.
Option RESET
OPTION LCDPANEL ST7735, L,GP8,GP12,GP9,GP13
No random pixels.
Power cycle -- random pixels (this time at the top row).
What seems to "clear" the random pixels is to toggle the settings on the orientation - then the first time is fine --- until a power cycle when the random pixels are back (either top row -- when orientation is "L" or bottom row -- when orientation is "RL")
As the panel is square will investigate "P" for orientation....
Any ideas or is my panel duff....?
N
Nimue
Posted: 05:53pm 05 Feb 2023
Update 2
It also appears that it is 1pixel out --
pixel 1,1 draws outside the lcdpanel
pixel 1,2 draw upper left (when in RL orientation).
Same behaviour when orientation set to "P".
N
Edited 2023-02-06 03:59 by Nimue
Nimue
Posted: 09:13am 06 Feb 2023
Final update...
Digging into the Wiki for the Waveshare I find this....
"ST7735S is a 132*162 pixel LCD controller, and this product is a 128*128 pixel LCD, so some processing has been done on the display: the display starts from the second pixel in the horizontal direction, so that the display can be guaranteed. At that time, the position corresponding to the RAM in the LCD is consistent with the actual position."
So that explains the pixel offset and the "processing" / references to positions in RAM (on the LCD) probably explains the slight incompatibility.
Moral of the story --- read the Wiki before you buy "non standard" parts ;-)
N
Posted: 09:17am 06 Feb 2023
If you want to loan me the display I can create a variant of the driver to suit.PM me if interested
Nimue
Posted: 09:40am 06 Feb 2023
  matherp said  If you want to loan me the display I can create a variant of the driver to suit.PM me if interested
I really appreciate the offer - am conscious of adding to your commitments with something that might be niche --- I suppose semi custom panels will keep popping up and its impossible to keep them all compatible (or even desirable).
My use case (as most are) is to use in class somehow -- possibly to build a "simple" data logger.
Have PM'd
Diolch as we say in Wales.
TrevorH
Posted: 10:17am 06 Feb 2023
Hi, Nimue, you do realise that there are 3 versions of the ST7735 display, RED tab, GREEN tab and BLACK tab all of which require slightly different initialisation.
Just a thought!!!!
Trevor
Posted: 10:29am 06 Feb 2023
  TrevorH said  there are 3 versions of the ST7735 display, RED tab, GREEN tab and BLACK tab all of which require slightly different initialisation.
Trevor
Sorry to be dim but where are they? All I see is the one linked to (or similar but non-1.44 ones).
Edited 2023-02-06 20:30 by JohnS
Nimue
Posted: 11:58am 06 Feb 2023
  TrevorH said  Hi, Nimue, you do realise that there are 3 versions of the ST7735 display, RED tab, GREEN tab and BLACK tab all of which require slightly different initialisation.
Just a thought!!!!
Trevor
FWIW - they are GreenTabs.
N
Nimue
Posted: 12:00pm 06 Feb 2023
Trevor
The tabs refer to the tab colour on the screen protector when shipped -- its not shown online ;-)
(Least I hope that is what it is ;-) )
N
Posted: 02:27pm 06 Feb 2023
No wonder I didn't know & searches hadn't helped!
TrevorH
Posted: 02:45pm 06 Feb 2023
I only know this as I have met this before when programming using Arduino, the Adafruit libraries for these panels have different initialisations depending on Tab colour and of course size, I don't know if MMBasic has different options for them.
Peter, over to you
Trevor
