Local Time 09:13 15 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CSUB docs for CMM2
William Leue
Posted: 07:19pm 14 Feb 2023
I can't seem to find any details on how to make a CSUB for the CMM2. Unfortunately, the Search function on the forum only seems to run from the most recent posts and then backwards in time, and never gets to older posts.
I am hoping there is a doc or docs by Peter that give some details. My questions are:
1. What tools need to be used to compile (and link?) a C source file? I assume probably gcc, but certainly with some compilation options.
2. Can I pass a 2D array and work on it in the C function using **? I am guessing this might be hard.
Thanks!
-Bill
twofingers
Posted: 07:23pm 14 Feb 2023
  William Leue said  I can't seem to find any details on how to make a CSUB for the CMM2. Unfortunately, the Search function on the forum only seems to run from the most recent posts and then backwards in time, and never gets to older posts.
https://www.thebackshed.com/forum/ViewTopic.php?TID=12289&P=1
Michael
The lone and ...
Posted: 07:34pm 14 Feb 2023
  Quote  2. Can I pass a 2D array and work on it in the C function using **? I am guessing this might be hard.
No. Look at the source of some of the routines in MATHS.c for how to handle 2D arrays (They aren't really 2D). The PicoMite github code is identical to the CMM2 for this
William Leue
Posted: 07:36pm 14 Feb 2023
Thanks, Michael and Peter!
-Bill
