Frank N. Furter Guru Joined: 28/05/2012 Location: GermanyPosts: 1153
Posted: 12:51pm 16 Feb 2023
First: I have NEVER worked with Telnet.
- I have WLAN enabled (can see the neighbor's network). - Under Windows Features I have enabled Telnet - Raspberry Pico W was flashed with "2023-02-15_193513_PicoMiteWebV5.07.07a16" and "OPTION TELNET CONSOLE ON" was executed - Raspberry Pico W hangs on separate power supply and flashes - When I enter "telnet 192.168.1.111" in the console, I get the error message: "Could not connect to host, on port 23: connection error"
Also when I start TeraTerm (with the INI from Peter) I get the error message: "Connection timed out".
What am I doing wrong???
THANKS!
Frank
atmega8 Guru Joined: 19/11/2013 Location: GermanyPosts: 738
Posted: 01:41pm 16 Feb 2023
Frank, can you PING the Pico ? Disable the Windos Firewall globally.
You are shure about the correct IP? Look at your DHCP Server.
Posted: 01:42pm 16 Feb 2023
Please use Putty..... My 1. Choice
matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 11850
Posted: 02:03pm 16 Feb 2023
Frank
You need to enable wifi
OPTION WIFI ssid$, password$
Then when the Pico boots it will tell you its address. 192.168.1.111 is just the address my pico uses
Michal Senior Member Joined: 02/02/2022 Location: PolandPosts: 125
Posted: 02:06pm 16 Feb 2023
Or ask: ? mm.info(ip address)
Michal
Posted: 02:29pm 16 Feb 2023
This works for me:
option list PicoMite MMBasic Version 5.07.07a16 OPTION WIFI pabu19, ***************** OPTION TELNET CONSOLE ON > OPTION TCP SERVER PORT 80 Connected 192.168.178.36 Starting server at 192.168.178.36 on port 80
Posted: 06:28pm 16 Feb 2023
Ok, I think I'm missing any basics here - can someone give me a step-by-step guide for dummies? (I have no experience with network... )
I'm desperately searching the manual - how can I force a reboot again???
Frank
twofingers Guru Joined: 02/06/2014 Location: GermanyPosts: 1769
Posted: 06:41pm 16 Feb 2023
Hello Frank, First connect the Pico to the network with >OPTION WIFI "your ssid", "password"<. After the reboot you will get the IP address that you need to use for Teraterm.
Sorry, I'm still using Win7.
Regards Michael
... wird schon!
EDIT:
Power off/on? (USB-Hub with switches) Edited 2023-02-17 04:46 by twofingers‚My name is Ozymandias, king of kings Look on my works, ye Mighty, and despair!‘ Nothing beside remains. Round the decay Of that colossal wreck, boundless and bare The lone and ...
Posted: 06:48pm 16 Feb 2023
Hi Michael,
first stupid question: Do I have to determine the SSID and the PASSWORD?
Frank
...ich hoff's... (I hope so...)
JohnS Guru Joined: 18/11/2011 Location: United KingdomPosts: 4378
Posted: 07:05pm 16 Feb 2023
Commonly a label on your router.
(Or look in your OS settings if using WiFi.)
Posted: 07:13pm 16 Feb 2023
Hi John,
I think I understand.
I assumed that DIRECTLY from my computer can access it. So I DO NOT need to activate the computer's WiFi but the WiFi of the router to which the computer is connected???
Frank Edited 2023-02-17 05:16 by Frank N. Furter
Posted: 07:15pm 16 Feb 2023
SSID = your network/Wifi name. Password = Your Wifi password.‚My name is Ozymandias, king of kings Look on my works, ye Mighty, and despair!‘ Nothing beside remains. Round the decay Of that colossal wreck, boundless and bare The lone and ...
Posted: 07:16pm 16 Feb 2023
Correct! Edited 2023-02-17 05:17 by twofingers‚My name is Ozymandias, king of kings Look on my works, ye Mighty, and despair!‘ Nothing beside remains. Round the decay Of that colossal wreck, boundless and bare The lone and ...
Posted: 07:20pm 16 Feb 2023
Ok, then I will have to activate a separate WLAN and connect my computer to this router. My "normal" WLAN is too far away here...
Frank
Posted: 07:25pm 16 Feb 2023
Ah. I guessed you'd have WiFi within range of your Pico W.
Posted: 08:14pm 16 Feb 2023
MANY THANKS TO ALL OF YOU FOR YOUR HELP!
No sooner do you do it right, than it works!
I have now connected a separate router with activated WLAN to my computer, read the SSID from it and entered it together with the WLAN password into the PicoMite.
