Grogster Admin Group Joined: 31/12/2012 Location: New ZealandPosts: 10038
Posted: 11:16pm 02 Mar 2023
I might be wrong here, but I seem to recall reading somewhere from Peter, that he used TinyFS cos anything larger gobbles up too much of the very valuable RAM in the 2040 chip. If I am remembering that correctly, then upgrading the FS won't be something that will be happening anytime soon I would think - other then squishing any bugs found, naturally. I expect Peter and others more in the know here with the internal details then I, will comment and tell me if that is correct or I am wrong. But that is what I seem to remember.Smoke makes things work. When the smoke gets out, it stops!
matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 11850
Posted: 07:14am 03 Mar 2023
picomite uses Full FatFS for SD and LitteFS for flash. FatFS does not support wear levelling. LittleFS does
Michal Senior Member Joined: 02/02/2022 Location: PolandPosts: 125
