asknik2022 Regular Member Joined: 26/03/2022 Location: United KingdomPosts: 94
Posted: 05:08pm 03 Mar 2023
OPTION BASE 1
'Define color lookup table
DIM rgb%(4,3) rgb%(1,1)=255: rgb%(1,2)=255: rgb%(1,3)=0 'YELLOW rgb%(2,1)=255: rgb%(2,2)=0: rgb%(2,3)=0 'RED rgb%(3,1)=0: rgb%(3,2)=0: rgb%(3,3)=255 'BLUE rgb%(4,1)=0: rgb%(4,2)=128: rgb%(4,3)=0 'GREEN 'Set up the Spirograph parameters r1 = 90 r2 = 30 p = 60 colorindex =0 'Set up the rotation parameters cx = 120 cy = 160 angle = 0 angle_step = 0.5
CLS
DO getcol sa = SIN(angle) ca = COS(angle) 'Calculate the Spirograph path FOR t = 0 TO 360 STEP 1 a = (r1-r2)/r2 x = (r1-r2)*COS(t) + p*COS(a*t) y = (r1-r2)*SIN(t) - p*SIN(a*t)
'Rotate the coordinates and draw a pixel xp = cx + INT(x*ca - y*sa) yp = cy + INT(x*sa + y*ca) Pixel xp,yp,rgb(rgb%(colorindex,1),rgb%(colorindex,2),rgb%(colorindex,3))
NEXT t ' Update the angle and wait a bit before redrawing angle = angle + angle_step
LOOP
sub getcol ' Set color colorindex=int(rnd*3)+1 end sub
homa Guru Joined: 05/11/2021 Location: GermanyPosts: 690
Posted: 08:36pm 03 Mar 2023
cx = 120 cy = 160
switch to
cy = 120 cx = 160
and add at the beginning
mode 2 Edited 2023-03-04 06:38 by homa
Posted: 08:04am 04 Mar 2023
This is for the picomite and the screen was set to portrait ili9341
Posted: 11:26am 04 Mar 2023
Ah, sorry. I use the PicoMiteVGA.
Andrew_G Guru Joined: 18/10/2016 Location: AustraliaPosts: 891
Posted: 05:22am 05 Mar 2023
@asknik, G'day and a belated "welcome" to the forum. A nice program, thanks. It is one of those things I enjoyed in my youth and it is good to now see it in MMBasic. I've fiddled with r1 & r2 (as well as Cx and Cy). I'll add it to the programs for my grandchildren.
