Forum Index : Microcontroller and PC projects : LCD Module DEM16217
| asknik2022 Regular Member Joined: 26/03/2022 Location: United KingdomPosts: 94 |
Hi Does anyone know if it is possible to connect this LCD Panel to a Micromite or picomite? Spec Below DEM 16217 SYH-PY LCD dot matrix modules • dot matrix modules with 2 lines and 16 characters • high contrast LCD-STN display • LED backlight • characters: black • by Display Elektronik • interface for 4- or 8-Bit data bus |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 11850 |
look for BITBANG LCD in the manual (special device support and the command list). Assuming the controller is standard then should work |
| Mixtel90 Guru Joined: 05/10/2019 Location: United KingdomPosts: 9128 |
Should be OK. There's a diagram in both the manuals showing how to do it. It's a generic LCD display, so look under "Special Device Support". It works in 4-bit mode. Mick Zilog Inside! nascom.info for Nascom & Gemini |
