Local Time 03:55 15 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Syntax error setting up ssd1963_4 on latest beta27
smileyint
Posted: 11:40am 13 Mar 2023
When upgrading from PicoMiteV5.07.07b10 to b27. Setting up the touch display SSD1963_4 using OPTION LCDPANEL SSD1963_4, L, GP13, GP16, GP9 resulted syntax error. Shortening the command with less arguments also error. Reconnecting the PicoMite also in vain. However, reverting to b10 again is successful thus i sticking with b10 until there are newer betas. Understood betas may have bugs and hope this will help for newer stable version.
Posted: 01:10pm 13 Mar 2023
Thanks for the report - will fix
UPDATE now OK if you download from Geoff's site again
Edited 2023-03-13 23:55 by matherp
smileyint
Posted: 08:36am 19 Mar 2023
  matherp said  Thanks for the report - will fix
Dear Matherp, I redownload and try again and it seems to work without the gp pins. At least that working now. Thank you for your effort.
