Local Time 01:13 15 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Pico ADK
Quazee137
Posted: 12:25pm 01 Apr 2023
Will this run MMBasic
 Pico ADK
 Quazee137
Posted: 02:53pm 01 Apr 2023
It certainly isn't supported by MMBasic. You'd need to write your own routines to work with it. Note that it uses I2S so you are starting from scratch.
It won't work with the PicoMite VGA firmware (VGA pins are used for something else).
Pin GP25 (heartbeat LED) is used for something else.
TBH I. personally, wouldn't attempt it. It would be easier to learn C or Python, I think.
Quazee137
Posted: 04:07pm 03 Apr 2023
Not looking at using the VGA. With the new library might be FUN to play with
my other MIDI systems but using MMBasic.
Posted: 05:16pm 03 Apr 2023
If you want a MIDI interface on a standard PicoMite then surely all you need is a buffered output (to get the 5V drive necessary) and an opto-coupler then put them on a COM port. Oh, and a bit of software. ;)
It looks like the latest beta is going to be fun for you anyway, without getting a device that isn't fully supported. :)
hitsware2
Posted: 06:26pm 03 Apr 2023
Or This ... Or This ... Or This ...
Or This ...
And not need the opticoupler ...
my site
Posted: 08:22pm 03 Apr 2023
Lovely if you want to make sounds but not very effective if you want to control remote MIDI devices. :)
