Forum Index : Microcontroller and PC projects : PicoMiteVGA: SPRITE Write vs SPRITE Show
| Hawk Senior Member Joined: 15/07/2021 Location: AustraliaPosts: 158 |
Could someome please explain the practical difference between using SPRITE Write verse using SPRITE Show? This time I have RTFM first but am still not clear when I would use one or another. For my playing card program, I am considering creating sprites on the fly, only when I need to move a card on the screen from one location to another. The issue is how to maintain what is under the sprite as it moves. (and to eliminate the tearing...but I thinking that GetScanLine might be able to help me there. Hawk |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 11844 |
sprite write just copies the sprite to the output replacing anything that was there before. sprite show restores to previous background (if not the first show), saves the new background and then writes the sprite. In other words write is one way, show allows the sprite to be moved without impacting the background |
Thanks for the manual suggestions. I will have to think about this one. The intention with the manual was to spell out in detail the typical things that new users would want to do and, for the more specialised functions, to just provide a high level summary (although this was not perfectly followed). Otherwise the manual would have become way too big. As I said, it will require some thought, Geoff Geoff Graham - http://geoffg.net |
Thanks for the explanation, that helps a lot. I used: DO WHILE GetScanLine < 479: LOOP SPRITE Show card, x, y, 0 To eliminate the tearing. The only problem now is to spped it up. That will probably involve larger step increments. It won't be as smooth, but hopefully if it is fast enough that it won't be noticed so much. I need to get my audio circuit built so that I work on playing the movement with playing WAV files. I hope that they load fast enough. Regarding the manual, I'm a new user, so it's that first place I go looking for answers. Sometimes I then search through old forum threads, but they are not always relevent to the PicoMiteVGA that I am using. If you are sick of manual suggestions, just say. I'll try to limit it to inconsistencies that have been introduced as MMBASIC has evolved for the specific PicoMite that I'm using. Hawk |
