Local Time 17:07 14 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : WebMite firmware, ILI9844W functionality
NPHighview
Posted: 10:48pm 09 Jun 2023
After attempting to port hhtg1968's program to the WebMite and the WaveShare Pico-Eval-Board display, I think I may have either uncovered a misunderstanding on my part, or an error in the WebMite documentation or firmware.
Page 133 of the WebMite manual says
  Quote  PIXEL(x,y [,page_number]) Returns the colour of a pixel on an LCD display. ... The display must use one of the SSD1963, ILI9341, ILI9488, or ST7789_320 controllers.
Here is the "minimal" test program I wrote:
Rem minimal test of ILI9844W functionality
CLS RGB(Blue)
Print MM.Info(LCDPANEL), MM.Info(VERSION)
Print Pixel(MM.HRes/2, MM.VRes/2)
Here is the result:
> RUN
ILI9488W         5.070801
[4] Print Pixel(MM.HRes/2, MM.VRes/2)
Error : Invalid on this display
Here is my setup:
WebMite MMBasic Version 5.07.08b1
OPTION SYSTEM SPI GP10,GP11,GP12
OPTION AUTORUN 4
OPTION COLOURCODE ON
OPTION POWER PWM ON
OPTION DISPLAY 60, 132
OPTION LCDPANEL ILI9488W, RPORTRAIT,GP8,GP15,GP9,GP13
OPTION WIFI ***********, *********
OPTION TOUCH GP16,GP17
GUI CALIBRATE 1, 139, 272, 840, 1285
OPTION SDCARD GP22, GP5, GP18, GP19
disco4now
Posted: 11:18pm 09 Jun 2023
ILI9488 and ILI9488W are implemented differently. ILI9488W does not allow read on the SPI so the Pixel function can not work.
F4 H7FotSF4xGT
Posted: 11:19pm 09 Jun 2023
Works for me.
PicoMite MMBasic Version 5.07.07RC7
Copyright 2011-2023 Geoff Graham
Copyright 2016-2023 Peter Mather
> AUTOSAVE
CLS RGB(Blue)
Saved 100 bytes
> save "ILI9488-pixel.bas"
> run
ILI9488  5.0707
252
> list
CLS RGB(Blue)
> ?hex$(pixel(mm.hres/2,mm.vres/2))
FC
> option list
OPTION KEYBOARD US
OPTION CPUSPEED (KHz) 378000
OPTION LCDPANEL ILI9488, RLANDSCAPE,GP21,GP20,GP17
OPTION GUI CONTROLS 40
OPTION TOUCH GP22,GP7
GUI CALIBRATE 0, 158, 282, 1252, 887
Are you sure your ILI9488 supports MISO (does BLIT READ work?)?
Posted: 11:22pm 09 Jun 2023
https://www.thebackshed.com/forum/ViewTopic.php?FID=16&TID=16001&LastEntry=Y#205585#205585
Search TBS, a lot has been said on this topic.
Posted: 07:37am 10 Jun 2023
The ILI9488W is not the ILI9488. The manual is correct. The ILI9488W does not and can not support reading the framebuffer. Check the schematic to understand why
NPHighview
Posted: 08:51pm 10 Jun 2023
Thank you, Peter. I suppose the "W" means "Write-Only".
hhtg1968
Posted: 09:08pm 10 Jun 2023
meanwhile i posted version 5 of this simulation...
lifepx5.bas.zip
