Local Time 15:08 14 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : [PICOMITE] - Soak test....
Posted: 08:29am 04 Jul 2023
I have been using the PM(WS Zero module) on a port from the PIC32 chip-based MMBASIC on the bench now for about six months.
Test FW: Version V5.07.06 (Non VGA PM)
I can report that this device continues to operate whenever it is asked, and therefore, I consider the PM port to be stable.
Not including the LATEST release FW, naturally, but.....
This is a good result(six months running on the bench), as in all the random tests I did of it since powering it up, it has never failed to provide the required results.
I consider this to be really rather a good result, and a stable port.
Some software you test, can fall-over in just a few hours or days, depending on the stability of the port, so - yeah - good stuff!
Edited 2023-07-04 18:31 by Grogster
circuit
Posted: 08:40pm 04 Jul 2023
That is excellent news and a perfect tribute to the skills and attention to detail that the authors put into it.
I remain in awe and gratitude for the talent and determination of Geoff and Peter.
