Local Time 15:08 14 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PWM problem, probably me but..
DaveJacko
Posted: 09:15pm 09 Jul 2023
PicoMite, absolutely fabulous, next job making an accurate pedometer.
(the accelerometer should be taped to the big toe for best results)
then no need for complex maths.
I just want a beep, what am I doing wrong. (it's usually me)
setpin gp2,pwm1a
pwm 1,256,50,0
error = 'pin not set for pwm'
also, while I'm at it,
do flag=1
loop until flag
'not a biggie, but be aware
regs Dave
Try swapping 2 and 3 over
ice2642
Posted: 09:40pm 09 Jul 2023
1 - Do you set the option power pwm ? (page 57)
2 - Look in the manual 87 page for the pwm configuration.
3 - look in page 92 for the correct setpin with pwm use.
I hope it help you.
Best regards,
MMBasic 5.0707 on PicoMite VGA
Posted: 09:43pm 09 Jul 2023
You are setting a value (0) for pwm1b. Just omit the ",0"
DaveJacko
Posted: 10:04pm 09 Jul 2023
That was quick! thanks Peter ! worked a treat. 'beeep'ed great !
Posted: 10:42pm 09 Jul 2023
Re DO, it's not clear what you're seeing or finding a problem with, but you need a ":" after DO.
Posted: 11:10pm 09 Jul 2023
Perhaps he is expecting an error as WHILE is usually the only thing that can follow DO.
Trapping every possible typo is a bit difficult.
