homa Guru Joined: 05/11/2021 Location: GermanyPosts: 686
Posted: 05:23pm 12 Jul 2023
Hello Webmite fans, Is there a way to detect when a terminal session is initiated to the Webmite via Telnet port 23, in order to then display current data in a running programme? For example, from an output update routine. Because now the screen remains blank and only when the programme sends output via print will it be displayed. Simply calling up the output every few seconds/minutes on suspicion is possible, but somehow not nice if I only look at the web site via Telnet once every few days ... These are supposed to be technician data that I do not want to output via the website. Matthias
matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 11842
Posted: 06:15pm 12 Jul 2023
The way the output works is that is only sends to connected devices. So if you have a serial console, usb console and telnet console all configured and nothing is connected the output simply disappears without a problem.
Just output the data and if/when you connect you will see it.
