Forum Index : Microcontroller and PC projects : Unable to write data to Thingspeak
| shoots Newbie Joined: 31/07/2011 Location: AustraliaPosts: 32 |
Hi, I have tried to write to Thingspeak using a WebMite. I have applied various combinations of IP address for the thingspeak site and ports and always receive "Failed to connect" error message. I have marked out passwords. I have been able send data to thingspeak via a url on a web page using https://api.thingspeak.com/update?api_key=I01xxxxxxxxxN7&field1=29 This works so I know the thingspeak side of things is OK. I have used my username and tried channel number in the MQTT fields to no avail. Any suggestions welcome please. Thank you, Peter OPTION EXPLICIT OPTION DEFAULT NONE option autorun 1 print MM.ver dim string channelID$="2xxxx" dim string apiKey$="Ixxxxxxxxxxx7" print channelID print apiKey 'to load via terminal when first running: 'option TCP SERVER PORT 80 'OPTION TELNET CONSOLE ON 'WEB NTP 8 'to get time later 'print TIME$ print MM.INFO(IP ADDRESS) WEB TCP INTERRUPT WebInterrupt dim integer CurrentTemp=TEMPR(GP15)'16 dim integer CurrentHumid=80 do print "test" pause 10000 loop sub WebInterrupt 'called when a request is made over the web CurrentTemp=TEMPR(GP15) 'this is a DB18S20 print "in subroutine" local integer a,p,t,b(512) FOR a=1 To MM.INFO(MAX CONNECTIONS)'Loop through all the incoming connections '(there could be a number of simultaneous connections) print a," number of connections" WEB TCP read a,b() 'Read the incoming message into the long string buffer print b(a) p=LINSTR(b(),"GET") 'Get the locations of key words in the message t=LINSTR(b(),"HTTP") 'Get the locations of key words in the message 'r = LINSTR(array%(), search$ [,start]) Returns the position of a string in a long string IF (p>0) And (t>p) then WEB TRANSMIT PAGE a%,"index.html" print TIME$ print "data ",a," a ",p," p ",t," t MMmax",MM.INFO(MAX CONNECTIONS) PRINT "Temperature: " TEMPR(GP15) sendThing endif next a end sub sub sendThing WEB MQTT CONNECT "192.168.1.137",1883,"Sxxxx","Sxxxxxx" WEB MQTT PUBLISH,"&field1","35" 'not working-possible wrong approach WEB OPEN TCP CLIENT https://api.thingspeak.com/update?api_key=I0xxxxxxxxxxxxxIN7&field1=39 '192.168.1.108 'Tried these IP '184.106.153.149 end sub |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 11842 |
WebMite can't support SSL over TLS which may be what Thingspeak needs. Not enough resource. Unless they have a non-secure port there is no solution |
Thank you matherp. Saves me sweating over it. I will give MicroPython a try- a pity as I have been enjoying the MMbasic environment for the last few years. Thank you for your work on it. Cheers, Peter |
| davematt Regular Member Joined: 27/09/2011 Location: AustraliaPosts: 55 |
@shoots, dont give up quite yet. In my ignorance I have been using a webmite to send to Thingspeak very reliably for some weeks. Got a hint from another member. Will forward his PM to you. And post code here if anyone else interested… Cheers, D |
| Bizzie Senior Member Joined: 06/07/2014 Location: AustraliaPosts: 194 |
I am sure not only me would like to see the code. Rob White |
Hi Rob, your wish is my command... To my knowledge, this has worked perfectly for 12 weeks, all credit to Peter of course, my cattle and I are extremely grateful. ' Thingspeak Test 1.1 'WebMite MMBasic Version 5.07.07 'OPTION SYSTEM SPI GP10,GP11,GP12 'OPTION AUTORUN ON 'OPTION CPUSPEED (KHz) 250000 'OPTION LCDPANEL ILI9488W, RLANDSCAPE,GP8,GP15,GP9,GP13 'OPTION WIFI ******** 'OPTION TOUCH GP16,GP17 'GUI CALIBRATE 0, 231, 3963, 1267, -837 'OPTION SDCARD GP22 option explicit option default none option autorun on Dim m$,s$, n$, api_key$="XXXXXXXXXXXXXXXX" ' put your thingspeak key here DIM buff%(4096/8) m$="GET http://api.thingspeak.com/update?api_key="+api_key$+"&field1=" Do Getmessage ' waits for message from lo ra Batt = val(Arg$(3)) Level = val(Arg$(4)) Current = val(Arg$(5)) Status = Arg$(6) if timer > 1200000 then '20 mins s$=m$+Str$(Batt,0,1)+"&field2="+Str$(Current,0,1)+"&field3=" s$ = s$ + Str$(Level,0,0) + chr$(13) + Chr$(10) Web Open TCP Client "184.106.153.149",80 'fixed address for Thingspeak HTTP WEB TCP CLIENT REQUEST s$, buff%(4096/8) Pause 1000 buff%(4096/8) = 0 WEB close TCP Client end if Loop |
| lizby Guru Joined: 17/05/2016 Location: United StatesPosts: 3879 |
Davematt--thanks for posting your working code. Sometimes the key is not knowing that something "won't work". Note that you can preserve the formatting of your code when posting (which I suspect you had by the single space indent following the "if") by enclosing it within the tags "[ CODE]" and "[ \CODE]" (upper case but without spaces) or by pasting it in after clicking the "code" button above the posting window. PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on FOTS |
| JohnS Guru Joined: 18/11/2011 Location: United KingdomPosts: 4378 |
Or attach as a file. John |
Hi Davematt, thank you for the encouragement and the program. I will have a go with it. I can see there's more than one way to achieve an outcome when it comes to programming. I spent some time grappling with MicroPython and ended up having a win but it was a tedious process! All good learning though. The little Pico W is a pretty cool item. Cheers, Peter |
