Forum Index : Microcontroller and PC projects : creating a vitual com port with custom baudrate on Win ?
| Plasmamac Guru Joined: 31/01/2019 Location: GermanyPosts: 620 |
Hi, is it possible to create a vitual serial com port with a custom baudrate ? i found no usefull free software for . maybe you can help ? thx Plasma |
| IanRogers Senior Member Joined: 09/12/2022 Location: United KingdomPosts: 152 |
I use COM0COM works on my win10. But I use it application to application as a virtual pair.. Its free. I'd give my left arm to be ambidextrous |
| lizby Guru Joined: 17/05/2016 Location: United StatesPosts: 3879 |
What sort of "custom" and for what usage? MMBasic for DOS supports serial ports with "any standard baud rate from 110 to 256000 bits per second" (but I don't know exactly what counts as "standard"). PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on FOTS |
| Mixtel90 Guru Joined: 05/10/2019 Location: United KingdomPosts: 9125 |
I'm not sure what the application is, but Tera Term will let you enter non-standard baud rates if you want a daft terminal speed like 13027 baud. :) Mick Zilog Inside! nascom.info for Nascom & Gemini |
thx for all the help , i use Tera Term over 10 years and never realized the input for my own Baudrates. thx Mixtel and all others Plasma |
