Local Time 10:52 14 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Webmite Manual v3 - JSON$ function
carlschneider
Posted: 06:27pm 30 Aug 2023
Hi there
It would appear that the JSON$ function is not present in the Function table of the manual, but is referenced on Pages 30 and 121.
On Page 120 the WATCHDOG entry appears to be duplicated.
Cheers Carl
Retirement is tough on Hobbies without a day job
carlschneider
Posted: 08:22pm 30 Aug 2023
Possibly this might help someone...
'JSON String Parsing Example
'JSON string format {"variable name1":"data string1","variable name2":"data string2", etc}
'In order to capture this in a piece of code we need the \q to replace the " see WebMite Manual Pg 35&36
'The command parses the LongString%() target for the "phrase" and returns the value after the :
'JSON$(LongString%(),"phrase")
'In demonstration consider the following
OPTION ESCAPE 'Allows certain ASCII characters to be embedded in strings through the use of \
PlayArea
Sub PlayArea
Local JSONString%(64/8) 'Dimension Integer Longstring
JSON1$="{\qa\q:99,\qb\q:0,\qc\q:45,\qd\q:\qcheese\q,\qe\q:\qspread\q}" 'Create JSON string as a normal string
LongString Append JSONString%(),JSON1$ 'Append the normal string to the declared  LongString
For i= 97 To 101 'ASCII 97 is a and ASCII 101 is e, effectively looping from a to e, the variable names
Print Json$(JsonString%(),Chr$(i));" "; 'Chr$(i) resolves to the string a through e in the For Loop
Next i
End Sub
Terminal Output
99 0 45 cheese spread
Cheers Carl
