Local Time 09:58 14 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : WEB TCP READ usage query
carlschneider
Posted: 08:55pm 10 Sep 2023
Here's to hoping somebody can please clarify.
In the Webmite Manual v3 for the
WEB TCP READ  cb%, buff%()
it states that
If there is data that has been received then the BASIC program must respond with one of the WEB TRANSMIT commands in order to respond and close the connection.
In my use case there is no WEB TRANSMIT FILE cb%, filename$, content-type$ option where content-type$ is "text/json".
I have instead used
WEB TCP SEND a%, buffer%()
WEB CLOSE TCP CLIENT a%
where buffer%() has the following headers and is correctly assembled, sent, received and processed by the requesting page.
HTTP/1.1 200 OK
Content-type:text/json
Connection: keep-alive
Content-length:...etc
Does the above code fulfil the WEB TCP READ requirement to respond and close the connection? It works for me but the web server does get lost when there is high traffic.
Cheers Carl
Retirement is tough on Hobbies without a day job
