Local Time 09:58 14 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Watering System Controller SC Aug 2023
macmite
Posted: 08:34am 12 Sep 2023
I am trying to load the Raspberry Pi pico W with the various files described in the Aug 2023 article using a Mac OS. v12.6.9
I have been using CoolTerm 2.0.1 as there is no mac version of Tera Term.
I was able to successfully copy the WebMite MMBasic Version 5.07.07 to the pico
I was able to enter the SSID and pwd for my local wifi router successfully.
The FILES and PRINT cmds work ok.
When I attempt to use the TFTP cmd I get Error : Unknown Command.
Copyright 2011-2023 Geoff Graham
Copyright 2016-2023 Peter Mather
Connecting to WiFi...
Connected 192.168.100.176
Starting server at 192.168.100.176 on port 80
> tftp
Error : Unknown command
> TFTP -i 192.168.100.176 PUT retic.bas
> TFTP -i ipaddress PUT retic.bas
> TFTP -i ipaddr PUT retic.bas
How can/do I load the retic.bas and associated files into the pico?
Mack
Posted: 08:49am 12 Sep 2023
The webmite is a tftp server. You need a tftp client for the mac and execute the commands there
macmite
Posted: 04:36pm 12 Sep 2023
Thanks matherp, I have now installed Pumpkin on my Mac and have used it to upload retic.bas and the related web server files.
All working OK
