Local Time 08:51 14 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Updated the pico compiler
gadgetjack
Posted: 12:42am 28 Sep 2023
For Mixtel90 . They have an updated firmware for the board you designed for me that ran the little compiler. It can now have a usb keyboard connected to edit and save code right on the little lcd. This makes it a bit easier to write code for it. Its at the same site as before on github. I did translate the F key codes if you want it. Helps with edits.
Jack
Posted: 06:41am 28 Sep 2023
Oh, yes - that was the little 4" square board with the ILI8341 and buttons, wasn't it? IIRC there's not much space on there for a PS/2 socket. :)
Isn't the text rather small and screen scrolling slow for editing on that display?
