Local Time 07:47 14 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Forced to enter 4 Pins? (OPTION COUNT pin1, pin2, pin3, pin4)
Amnesie
Posted: 10:49am 28 Sep 2023
Ahh me again,
of course I first looked into the manual, but it states only:
Specifies which pins are to be used as Count inputs.
By default these are GP6, GP7, GP8 and GP9.
The SETPIN command defines the Counter mode.
This command must be run at the command prompt (not in a program).
Problem: I don't have as many Pins left. My project consumes already all pins and
GP2 (pin 4) I have reserved for this job. Why I am forced to enter 4 Pins?
I lerned from another topic that it is possible to leave them "blank" like:
OPTION COUNT , , ,GP2
but then I get an SYNTAX ERROR...
I am afraid by just taking "random" Pins (which are already used by my program) I am introducing other conflicts or errors.
I just need one Pin as a Counting, and that's GP2, is that possible?
Best wishes and forgive my noobness! Sadly the manual doesn't tell me about that specific case..
Daniel
Edited 2023-09-28 20:51 by Amnesie
Posted: 11:13am 28 Sep 2023
Just specify any pins. If you don't use them as count pins it is completely benign.
Posted: 11:15am 28 Sep 2023
Peter answered it. :)
Edited 2023-09-28 21:16 by Mixtel90
Amnesie
Posted: 02:07pm 28 Sep 2023
Thank you, I thought if they are already in use there might be problems later on ...
Greetings
Daniel
