Forum Index : Microcontroller and PC projects : Umite Backpack 24 to 12 Hr Help
| Mickanical Newbie Joined: 21/11/2018 Location: AustraliaPosts: 2 |
Hi Folks I'm trying to convert 24hr to 12 Hr on a Umite Backpack. Project Code attached. Have added the following code from the manual after scouring the forum. 'As another example, let us say that you need a function to format time in the AM/PM 'format: FUNCTION MyTime$(hours, minutes) LOCAL h h = hours IF hours > 12 THEN h = h - 12 MyTime$ = STR$(h) + ":" + STR$(minutes) IF hours <= 12 THEN MyTime$ = MyTime$ + "AM" ELSE MyTime$ = MyTime$ + "PM" ENDIF END FUNCTION I get this error but i'm unsure how to declare it. RUN [70] Text 150,45,Str$(MYTIME),CM,1,2,RGB(WHITE),RGB(BLACK) Error: MYTIME not declared Any guidance is much appreciated Thanks Michael SPRINKLER ON TOUCH V4 Rev 3 AM PM.zip |
| twofingers Guru Joined: 02/06/2014 Location: GermanyPosts: 1769 |
Hi Michael, hmm, MYTIME <> MYTIME$ ? Regards Michael Please try: Text 150,45,MYTIME$(hour, minute),CM,1,2,RGB(WHITE),RGB(BLACK) There is more "bad" (less optimal) code: SUB PLANTS PIN(PLANTSOL)=1 'Sol 3 on TEXT 160,100," WATERING PLANTS ",CM,1,2,rgb(BLACK),RGB(BLUE) Countdown=Plantsmin Gosub Count PIN(PLANTSOL)=0 ' Finished watering TEXT 160,100," PLANTS DONE ",CM,1,2,rgb(WHITE),RGB(BLUE) end sub Count: CountLoop: TEXT 160,250,STR$(CountDown),CM,1,2,RGB(WHITE),RGB(BLUE) pause 1*MINS Countdown=Countdown-1 IF Countdown>0 then goto CountLoop endif end sub I would prefer this SUB PLANTS PIN(PLANTSOL)=1 'Sol 3 on TEXT 160,100," WATERING PLANTS ",CM,1,2,rgb(BLACK),RGB(BLUE) Countdown=Plantsmin Count_sub PIN(PLANTSOL)=0 ' Finished watering TEXT 160,100," PLANTS DONE ",CM,1,2,rgb(WHITE),RGB(BLUE) end sub Sub Count_sub do TEXT 160,250,STR$(CountDown),CM,1,2,RGB(WHITE),RGB(BLUE) pause MINS inc Countdown-1 'oops, I think "INC" is not available for MicroMites loop while Countdown>0 end sub ... untested Edited 2023-10-11 03:41 by twofingers ‚My name is Ozymandias, king of kings Look on my works, ye Mighty, and despair!‘ Nothing beside remains. Round the decay Of that colossal wreck, boundless and bare The lone and ... |
