Forum Index : Microcontroller and PC projects : PicoGUS - A Pico module based ISA sound card...
Grogster![]() Admin Group Joined: 31/12/2012 Location: New ZealandPosts: 10037 |
Quite interesting to see what others are using the Pico modules for! PicoGUS ISA sound card for retro gaming.... Smoke makes things work. When the smoke gets out, it stops! |
Quazee137![]() Guru Joined: 07/08/2016 Location: United StatesPosts: 603 |
LOL I posted this back on the 7th thinking is may be of use as its open source. And he showed a few other cards making use of the pico. Quazee137 |
Oh, did you?! Sorry for the double-thread then, everyone. Smoke makes things work. When the smoke gets out, it stops! |
Hi All, @Quazzie, I didn't see your earlier post either. I wonder why they used a Pico-W instead of a Pico? Regards, Mick Mick's uMite Stuff can be found >>> HERE (Kindly hosted by Dontronics) <<< |
| Plasmamac Guru Joined: 31/01/2019 Location: GermanyPosts: 620 |
This open the world for card with io powered by mmb4w Plasma |
@ Mick - perhaps they only had a W on-hand. As far as I can see from the video, they are not using the WiFi ability at all, so a standard Pico module would probably also work fine. @ Plasmamac - Nice idea, but I don't know that that would ever work. I expect the MMBASIC interpreter overhead would make it too slow to talk to the ISA bus, which I think runs at about 8MHz, so the Pico is PROBABLY using the PIO's and C to be able to talk to the PC ISA bus. I may be wrong, but I don't think MMBASIC would be fast enough for this kind of task. ![]() Smoke makes things work. When the smoke gets out, it stops! |
