Local Time 06:47 14 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : How many Erase / Rewrite cycles can I put my Pico's through?
EDNEDN
Posted: 02:06am 16 Oct 2023
Every time I edit a BASIC program on my Pico, it erases and rewrites it to the device.
And the same thing happens every time I make a tweak to the MMBasic firmware.  The device gets erased and rewritten.
How long until I start to have problems?
palcal
Posted: 05:16am 16 Oct 2023
Around 100,000 so I wouldn't worry about wearing it out.
Posted: 08:31am 16 Oct 2023
Just get a spare. Or two. :)
At 4-writes per hour, 24 hours day, 365 days per year, that would work out at about three years minimum if there's no wear-levelling. That's for the flash, of course, there's no restriction on RAM. In real life you could probably expect at least three times that.
EDNEDN
Posted: 01:13pm 16 Oct 2023
Wow!   Thank You so much for the information....
I was trying to figure out and resolve as many bugs and problems as possible before I did an erase / rewrite cycle.    I'm glad to know that isn't necessary.
Andy-g0poy
Posted: 06:03pm 16 Oct 2023
If you are really concerned then there are versions of MMBASIC for the PC Windows and Linux
(Linux)
https://github.com/thwill1000/mmb4l
(Windows)
https://geoffg.net/WindowsMMBasic.html
Obviously the IO parts of the pico ext will not be available, but if you are just sorting out standard routines then it's a useful testing setup.
Andy
